Increase storage capacity on ASA r2 storage systems
Add drives to a node or shelf to increase the storage capacity of your ASA r2 system.
Use NetApp Hardware Universe to prepare for installation of a new drive
Before you install a new drive to a node or shelf, use the NetApp Hardware Universe to confirm that the drive you want to add is supported by your ASA r2 system and to identify the correct slot for the new drive. The correct slots for adding drives vary depending on the system model and ONTAP version. In some cases, you need to add drives to specific slots in sequence.
Go to the NetApp Hardware Universe.
Under Products, select your hardware configurations.
Select your ASA r2 system.
Select your ONTAP version; then select Show Results.
Beneath the graphic, select Click here to see alternative views; then choose the view that matches your configuration.
Use the view of your configuration to confirm that your new drive is supported and identify the correct slot for installation.
You have confirmed that your new drive is supported and you know the appropriate slot for installation.
Install a new drive on the ASA r2
The minimum number of drives you should add in a single procedure is three. Adding a single drive might reduce performance.
Repeat the steps in this procedure for each drive.
Properly ground yourself.
Gently remove the bezel from the front of the system.
Insert the new drive into the correct slot.
With the cam handle in the open position, use both hands to insert the new drive.
Push until the drive stops.
Close the cam handle so that the drive is fully seated into the mid plane and the handle clicks into place.
Be sure to close the cam handle slowly so that it aligns correctly with the face of the drive.
Verify that the drive's activity LED (green) is illuminated.
If the LED is solid, the drive has power.
If the LED is blinking, the drive has power and I/O is in progress. The LED will also blink if the drive firmware is being updated.
Drive firmware is automatically updated (nondisruptively) on new drives that do not have current firmware versions.
If your node is configured for drive auto-assignment, wait for ONTAP to assign the new drives to a node. If your node isn’t configured for drive auto-assignment, or if you prefer, assign the drives manually.
The new drives are not recognized until they are assigned to a node.
After the new drives have been recognized, verify that they have been added and their ownership is specified correctly.
