Rename a node on an ASA r2 storage system
Contributors netapp-aherbin
You can use System Manager to rename a node on your ASA r2 system to align with the naming conventions of your organization or for other administrative reasons.
Steps
  1. In System Manager, select Cluster > Overview.
  2. Select three vertical blue dots next to the node you want to rename; then select Rename.
  3. Enter the new name for the node, then select Rename.
Result
The new name is applied to the node.
