Verify host connectivity on your ASA r2 storage system
If there is an issue with host data operations, you can use ONTAP System Manager to verify that the connection from your host to your ASA r2 storage system is active.
Steps
In System Manager, select Host.
System Manager displays the host connectivity status next to the host group name:
OK: Indicates that all initiators are connected to both nodes.
Partially Connected: Indicates that some of the initiators are not connected to both nodes.
None Connected: Indicates that no initiators are connected.
What's next?
Make updates on your host to correct connectivity issues. ONTAP will recheck the connection status every 15 minutes.
