Monitor cluster and storage unit performance on ASA r2 storage systems
Contributors netapp-aherbin
Use ONTAP System Manager to monitor the overall performance of your cluster and specific storage units, including latency, IOPS, and throughput, over spans of time ranging from one hour to one year.
For example, suppose a critical application is experiencing high latency and low throughput. When you view cluster performance for the last five business days, you notice a decrease in performance at the same time each day. You use this information to determine that the critical application is competing for cluster resources when a non-critical process begins running in the background. You can then modify your QoS policy to limit the impact of the non-critical workload on system resources and ensure that your critical workload meets minimum throughput targets.
Monitor cluster performance
Use cluster performance metrics to determine whether you need to shift workloads to minimize latency and maximize IOPS and throughput for your critical applications.
Steps
  1. In System Manager, select Dashboard.
  2. Under Performance, view the latency, IOPS, and throughput for the cluster by hour, day, week, month, or year.
  3. Select blue downward arrow to download the performance data.
What's next?
Use your cluster performance metrics to analyze if you need to modify your QoS policies or make other adjustments to your application workloads to maximize your overall cluster performance.
Monitor storage unit performance
Use storage unit performance metrics to determine the impact of specific applications on latency, IOPS, and throughput.
Steps
  1. In System Manager, select Storage.
  2. Select the storage unit you want to monitor; then select Overview.
  3. Under Performance, view the latency, IOPS, and throughput for the storage unit by hour, day, week, month, or year.
  4. Select blue downward arrow to download the performance data.
What's next?
Use your storage unit performance metrics to analyze whether you need to modify the QoS policies assigned to your storage units to decrease latency and maximize IOPS and throughput.
