Optimize cluster security and performance with ASA r2 system Insights
View Insights in ONTAP System Manager to identify best practices and configuration modifications that you can implement on your ASA r2 system to optimize cluster security and performance.
For example, suppose you configured fewer than the recommended number of Network Time Protocol (NTP) servers for your cluster. To help you prevent problems that inaccurate cluster time can cause, Insights notifies you that too few NTP servers are configured and gives you options to learn more, fix the issue, or dismiss it.
Steps
In System Manager, select Insights.
Review recommendations.
What's next
Perform any necessary actions to implement best practices and optimize your cluster security and performance.
