Astra Automation 22.08
List users
Contributors dmp-netapp
You can list the users that are defined for a specific Astra account.
1. List the users
Perform the following REST API call.
HTTP method Path
GET
/account/{account_id}/core/v1/users
Additional input parameters
In addition to the parameters common with all REST API calls, the following parameters are also used in the curl examples for this step.
Parameter Type Required Description
include
Query
No
Optionally select the values you want returned in the response.
Curl example: Return all data for all users
curl --location -i --request GET 'https://astra.netapp.io/accounts/<ACCOUNT_ID>/core/v1/users' --header 'Accept: */*' --header 'Authorization: Bearer <API_TOKEN>'
Curl example: Return the first name, last name, and id for all users
curl --location -i --request GET 'https://astra.netapp.io/accounts/<ACCOUNT_ID>/core/v1/users?include=firstName,lastName,id' --header 'Accept: */*' --header 'Authorization: Bearer <API_TOKEN>'
JSON output example
  "items": [
    "David",
    "Anderson",
    "844ec6234-11e0-49ea-8434-a992a6270ec1"
      "Jane",
      "Cohen",
      "2a3e227c-fda7-4145-a86c-ed9aa0183a6c"
  "metadata": {}
