Retrieve a feature
GET /accounts/{account_id}/core/v1/features/{feature_id}
Returns the stored Feature API resource in the JSON response body.
Name | Type | In | Required | Description |
account_id |
string |
path |
True |
feature_id |
string |
path |
True |
ID of the feature collection to list |
Status: 200, Returns the stored Feature API resource in the JSON response body.
Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
id |
string |
True |
name |
string |
True |
JSON string containing a name for the feature, in hierarchal dot notation. Defined values are:
isEnabled |
string |
True |
JSON string containing a value indicating whether the feature flag is turned on or off. Defined values are:
metadata |
True |
"type": "application/astra-feature",
"version": "1.0",
"id": "c4fdb3b8-9ca8-523d-b9d9-f7727b753612",
"name": "astra.account.rbac",
"isEnabled": "true",
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata
Conforms to the Astra Metadata Schema
labels |
array[type_astra_label] |
True |
creationTimestamp |
string |
True |
modificationTimestamp |
string |
True |
createdBy |
string |
True |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
