Retrieve an LDAP user
GET /accounts/{account_id}/core/v1/ldapUsers/{ldapUser_id}
Returns a JSON object representing the stored LDAP resource.
account_id
string
path
True
  • example: {{.Account}}
ldapUser_id
string
path
True
ID of the ldapUser collection to list
Status: 200, Returns a JSON object representing the stored LDAP resource.
type
string
True
  • "application/astra-ldapUser"
version
string
True
  • "1.0"
id
string
True
email
string
False
JSON string representing the email of the LDAP user. Defined values are:
  • Minimum length: 3
  • Maximum length: 63
firstName
string
False
JSON string representing the first name of the LDAP user. Defined values are:
  • Minimum length: 1
lastName
string
False
JSON string representing the last name of the LDAP user. Defined values are:
  • Minimum length: 1
cn
string
False
JSON string representing the LDAP group name. Defined values are:
  • Minimum length: 1
dn
string
False
JSON string representing the distinguished name of the LDAP group. Defined values are:
  • Conforms to RFC 4514
metadata
type_astra_metadata
True
  • Conforms to the Astra Metadata Schema
  "type": "application/astra-ldapUser",
  "version": "1.0",
  "id": "2add73ff-89dc-5ff1-be85-39d97549556d",
  "email": "johndoe@example.com",
  "firstName": "John",
  "lastName": "Doe",
  "cn": "John Doe",
  "dn": "cn=John Doe,ou=people,dc=example,dc=com",
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
Example error response
  "status": "404"
type_astra_label
name
string
True
value
string
True
type_astra_metadata
labels
array[type_astra_label]
True
creationTimestamp
string
True
string
True
createdBy
string
True
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
