Retrieve a setting
GET /accounts/{account_id}/core/v1/settings/{setting_id}
Returns the stored Setting API resource in the JSON response body.
Name | Type | In | Required | Description |
account_id |
string |
path |
True |
setting_id |
string |
path |
True |
ID of the setting collection to list |
Status: 200, Returns the stored Setting API resource in the JSON response body.
Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
id |
string |
True |
name |
string |
True |
JSON string containing a name for the setting, in hierarchal dot notation (.). Defined values are:
currentConfig |
True |
JSON object containing keys and values that make up the current configuration for this setting. The contents of this object must conform to the JSON Schema contained in the configSchema field. Default values are supplied by the configmap. After defaults are changed by the user, they will not be overwritten. |
desiredConfig |
False |
JSON object containing keys and values that make up the requested configuration for this setting. The contents of this object must conform to the JSON schema contained in the configSchema field. The object does not exist until specified. When specified, this triggers the feature service to notify the corresponding service to request that the desired configuration can be applied. The corresponding service can then perform validation and apply the desired configuration to the current configuration. |
configSchema |
True |
JSON object containing the JSON schema for the config property in this resource. Must conform to JSON Schema Draft 7. If config values are present in the resource, validation against the indicated configSchema is mandatory. As a common convention, configurations are recommended to have an "isEnabled" field, when appropriate. The "isEnabled" field contains a value that indicates whether the setting is turned on ("true") or off ("false"). |
state |
string |
True |
JSON string containing a value indicating the operational state of the application. Defined values are:
stateUnready |
array[string] |
True |
JSON array of JSON strings, each indicating a reason why the setting was not successfully applied. Defined values are:
metadata |
True |
"type": "application/astra-setting",
"version": "1.0",
"id": "7d490413-446b-5f86-8818-744e1c10a6c6",
"name": "astra.account.smtp",
"currentConfig": {
"credential": "",
"isEnabled": "false",
"port": 587,
"relayServer": "smtp.sendgrid.net"
"configSchema": {
"$schema": "http://json-schema.org/draft-07/schema#",
"title": "astra.account.smtp",
"type": "object",
"properties": {
"credential": {
"type": "string",
"description": "The credential ID for SMTP authentication."
"isEnabled": {
"type": "string",
"description": "This property determines if this setting is enabled or not."
"port": {
"type": "integer",
"description": "The SMTP port. For an unencrypted or a TLS connection, use port 25, 2525, or 587."
"relayServer": {
"type": "string",
"description": "This setting is sometimes referred to as the external SMTP server or the SMTP relay."
"additionalProperties": false,
"required": [
"relayServer",
"port",
"isEnabled"
"state": "valid",
"stateUnready": [],
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
type_json
type_json
properties
type_json_schema
$schema |
string |
True |
type |
string |
True |
properties |
True |
additionalProperties |
boolean |
True |
required |
array[string] |
True |
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
