Retrieve a role binding for a user
GET /accounts/{account_id}/core/v1/users/{user_id}/roleBindings/{roleBinding_id}
Returns the stored Role Binding API resource in the JSON response body. If the request is against /accounts/{account_id}/core/v1/users/{user_id}/roleBindings endpoint, only roleBinding resources where the user ID matches the user ID in the request URL will be permitted to be read. If the request is against /accounts/{account_id}/core/v1/groups/{group_id}/roleBindings, only roleBinding resources where the group ID matches the group ID in the request URL will be permitted to be read.
Name | Type | In | Required | Description |
account_id |
string |
path |
True |
user_id |
string |
path |
True |
ID of the containing user resource |
roleBinding_id |
string |
path |
True |
ID of the roleBinding collection to list |
Status: 200
Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
id |
string |
True |
principalType |
string |
True |
JSON string representing the type of the principal this binding is associated with. Defined values are:
userID |
string |
True |
JSON string containing a user resource ID. Defined values are:
groupID |
string |
True |
JSON string containing a group resource ID. Defined values are:
accountID |
string |
True |
JSON string containing the ID of an account resource. For create, this must match the account ID in the request URI. Defined values are:
role |
string |
True |
JSON string containing one of the four defined roles. Defined values are:
roleConstraints |
array[string] |
False |
JSON array of JSON strings specifying the scope of the role assignment. Defined values are:
metadata |
True |
"type": "application/astra-roleBinding",
"version": "1.1",
"id": "a198f052-5cd7-59d3-9f27-9ea32a21fbca",
"principalType": "user",
"userID": "4c27d25a-9edb-4e85-9438-48dc8e917231",
"groupID": "00000000-0000-0000-0000-000000000000",
"accountID": "9fd87309-067f-48c9-a331-527796c14cf3",
"role": "viewer",
"roleConstraints": [
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
