Retrieve an application backup
GET /accounts/{account_id}/topology/v1/appBackups/{appBackup_id}
Returns the stored Application Backup API resource in the JSON response body.
Name | Type | In | Required | Description |
account_id |
string |
path |
True |
appBackup_id |
string |
path |
True |
ID of the appBackup collection to list |
Status: 200, Returns the stored Application Backup API resource in the JSON response body.
Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
id |
string |
True |
name |
string |
True |
JSON string containing a user-specified name for the backup. If not specified, or when backups are initiated by a schedule, the system will assign a name for the backup. Defined values are:
bucketID |
string |
True |
JSON string containing an optional bucket ID that indicates where the backup will be stored on create. If not specified, a system-selected bucket is used. If no buckets are available, an error will be returned on create. Defined values are:
snapshotID |
string |
False |
JSON string containing the snapshot that was used to create the backup. To create the backup, a snapshot ID associated with the application being backed up can be specified on create. If not specified, a new snapshot will be created for the backup. Defined values are:
scheduleID |
string |
False |
JSON string containing an optional schedule ID that indicates that the backup was triggered by a schedule and which schedule triggered the backup. Only present for backups initiated by a schedule. Defined values are:
state |
string |
True |
JSON string containing a value indicating the operational state of the backup. Defined values are:
stateUnready |
array[string] |
True |
JSON array of JSON strings, each indicating a reason why an application backup is unable to transition to "running", or why it has transitioned to "failed" or "removed". Defined values are:
hookState |
string |
False |
JSON string containing a value indicating the state of any execution hooks run as part of snapshot. Defined values are:
hookStateDetails |
array[type_astra_stateDetails] |
False |
JSON array of JSON objects which lists additional details about why "hookState" transitioned into "failed". If no details are available, this array will be empty.
backupCreationTimestamp |
string |
False |
JSON string containing a timestamp indicating when the backup was taken. Defined values are:
totalBytes |
number |
False |
JSON number containing the total number of bytes in the backup. |
bytesDone |
number |
False |
JSON number containing the number of bytes backed up for a running backup. When the backup is completed, it matches with the totalBytes field. |
percentDone |
number |
False |
JSON number containing the percentage complete for a running backup. When the backup is completed, it is set to "100". |
metadata |
True |
"type": "application/astra-appBackup",
"version": "1.1",
"id": "54fe651d-3d3b-5fa8-b85c-5db757885ff3",
"name": "app-name-245",
"bucketID": "0afbe357-a717-4c7a-8b3d-d0368959c8de",
"scheduleID": "1fe83650-9b3c-41ef-bb25-a2910c19c33e",
"state": "pending",
"stateUnready": [],
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 500, Internal server error
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
"type": "https://astra.netapp.io/problems/95",
"title": "Backup not retrieved",
"detail": "The backup wasn't retrieved because of an internal server issue.",
"status": "500"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
type |
string |
True |
title |
string |
True |
detail |
string |
True |
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels.
labels |
array[type_astra_label] |
True |
creationTimestamp |
string |
True |
modificationTimestamp |
string |
True |
createdBy |
string |
True |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
