Retrieve a bucket
GET /accounts/{account_id}/topology/v1/buckets/{bucket_id}
Returns the stored Bucket API resource in the JSON response body.
account_id
string
path
True
  • example: {{.Account}}
bucket_id
string
path
True
ID of the bucket collection to list
Status: 200, Returns the stored Bucket API resource in the JSON response body.
type
string
True
  • "application/astra-bucket"
version
string
True
  • "1.0"
  • "1.1"
  • "1.2"
id
string
True
name
string
True
JSON string containing a user-assigned name for the bucket. Defined values are:
  • Minimum length: 1
  • Maximum length: 256
credentialID
string
True
JSON string containing the identifier of the credentials used to access the bucket. Defined values are:
  • Conforms to the Astra Identifier Schema
state
string
True
JSON string containing a value indicating the operational state of the bucket. Defined values are:
  • "pending" - The bucket is scheduled for discovery
  • "available" - The bucket is available for use
  • "failed" - The bucket is in a permanent failure state
  • "removed" - The bucket is not currently accessible
  • "unknown" - The bucket state cannot be determined
stateDetails
array[type_astra_stateDetails]
True
JSON array of JSON objects that lists additional details about why "state" transitioned to "removed" or "failed". If no details are available, this array will be empty.
  • Minimum items: 0
provider
string
True
JSON string indicating the bucket protocol that can be used to access the bucket. Defined values are:
  • "ontap-s3"
  • "storagegrid-s3"
  • "generic-s3"
  • "gcp"
  • "azure"
  • "aws"
bucketParameters
bucketParameters
True
JSON object that provides bucket provider-specific information required to access the bucket. The specific values in this bucket differ per provider.
metadata
type_astra_metadata_update
True
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
  "type": "application/astra-bucket",
  "version": "1.2",
  "id": "9b296ce0-c545-5022-acfa-1980c5aaea97",
  "name": "Test Bucket",
  "credentialID": "8f039324-7795-40bf-a5ca-4442580f7ab0",
  "state": "available",
  "stateDetails": [],
  "provider": "gcp",
  "bucketParameters": {
    "gcp": {
      "bucketName": "bucketName"
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
Example error response
  "status": "404"
type
string
True
title
string
True
detail
string
True
s3
JSON object that provides Simple Storage Service (S3) protocol parameters. (Use this object for all S3 type providers).
serverURL
string
True
JSON string containing a URL to the base path for the bucket. Defined values are:
  • Minimum length: 0
  • Maximum length: 1023
bucketName
string
True
JSON string containing the name of the S3 bucket. Defined values are:
  • Minimum length: 0
  • Maximum length: 63
gcp
JSON object that provides Google Cloud protocol parameters.
bucketName
string
True
JSON string containing the name of the backing Google Cloud bucket name. Defined values are:
  • Minimum length: 0
azure
JSON object that provides Azure protocol parameters.
storageAccount
string
True
JSON string containing the Azure storage account name. Defined values are:
  • Minimum length: 0
bucketName
string
True
JSON string containing the name of the backing Azure blob name. Defined values are:
  • Minimum length: 0
bucketParameters
s3
s3
False
gcp
gcp
False
azure
azure
False
type_astra_label
name
string
True
value
string
True
labels
array[type_astra_label]
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
