Retrieve a cluster
GET /accounts/{account_id}/topology/v1/clusters/{cluster_id}
Returns the stored Cluster API resource in the JSON response body.
Name | Type | In | Required | Description |
account_id |
string |
path |
True |
cluster_id |
string |
path |
True |
ID of the cluster collection to list |
Status: 200, Returns the stored Cluster API resource in the JSON response body.
Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
id |
string |
True |
name |
string |
True |
JSON string containing a name for the cluster. If not specified, the Kubernetes name of the cluster will be used. Defined values are:
state |
string |
True |
JSON string containing a value indicating the operational state of the cluster. Defined values are:
stateUnready |
array[string] |
True |
JSON array of JSON strings, each indicating a reason why the cluster is unable to transition to "running" state, when there are issues while in "running" state, or why it has transitioned to "failed" or "removed" state. Defined values are:
managedState |
string |
True |
JSON string containing a value indicating the management state of the cluster. Defined values are:
protectionState |
string |
True |
JSON string containing a value indicating the protection state of the cluster. Defined values are:
protectionStateDetails |
array[type_astra_stateDetails] |
True |
JSON array of JSON objects which lists additional details about the current protection state, including why the current state was reached. If no details are available, this array will be empty. Defined values are:
restoreTargetSupported |
string |
False |
JSON string containing a value indicating the ability of the cluster to be a target of application data management operations. Defined values are:
snapshotSupported |
string |
False |
JSON string containing a value indicating the ability of the cluster to perform application data management backup-like operations. Defined values are:
managedStateUnready |
array[string] |
True |
JSON array of JSON strings, each indicating a reason why the cluster is ineligible to be managed, or that the cluster is managed but non-fatal errors were encountered while managing the cluster. Defined values are:
managedTimestamp |
string |
False |
JSON string containing the timestamp indicating when the cluster was brought under management. Defined values are:
tridentVersion |
string |
False |
JSON string containing the version of Trident installed on the cluster. Defined values are:
tridentManagedState |
string |
False |
JSON string containing one of a set of enumerated values indicating the management state of Trident on this cluster. Defined values are:
tridentManagedStateDesired |
string |
False |
JSON string containing a value indicating the desired management state for Trident. Defined values are:
tridentManagedStateDetails |
False |
JSON array of JSON objects that lists additional details about why the state transitioned to "managed" or "unmanaged".
tridentManagedStateAllowed |
array[string] |
False |
States that can be requested in a given tridentManagedState. The following states can be requested in each defined state:
inUse |
string |
True |
JSON string containing a value indicating if the cluster has any managed applications and therefore cannot be deleted. Defined values are:
accHost |
string |
False |
JSON string that indicates that this cluster hosts the instance of Astra Control Center that is currently being accessed. Defined values are:
clusterType |
string |
True |
JSON string containing a value indicating the type of cluster. Defined values are:
clusterVersion |
string |
False |
JSON string containing a value indicating the semantic versioning representation of the cluster environment. For Kubernetes clusters, this is the Kubernetes version. Defined values are:
clusterVersionString |
string |
False |
JSON string containing a value indicating the extended versioning information for the cluster environment. For Kubernetes clusters, this is the full Kubernetes version. Defined values are:
clusterCreationTimestamp |
string |
False |
JSON string containing the timestamp indicating when the cluster was originally created. Defined values are:
namespaces |
array[string] |
False |
JSON array of JSON strings, each indicating a namespace within the cluster. Defined values are:
defaultStorageClass |
string |
False |
JSON string containing a storageClass ID that corresponds to the default storage class set in Kubernetes. Defined values are:
cloudID |
string |
True |
JSON string containing a value indicating the ID of the cloud the cluster is running on. Defined values are:
credentialID |
string |
False |
JSON string containing a value indicating the ID of the credential that contains the kubeconfig file for the cluster. Defined values are:
location |
string |
False |
JSON string containing a value provided by the cloud that the cluster is running on, indicating the cloud-specific location of the cluster. Defined values are:
isMultizonal |
string |
False |
JSON string containing a value provided by the cloud the cluster is running on, indicating whether the cluster spans two or more availability zones. Defined values are:
privateRouteID |
string |
False |
JSON string containing the location ID for private clusters.
apiServiceID |
string |
False |
JSON string containing the UUID from the Kubernetes (k8s) API service object. Used to uniquely identify a cluster. |
metadata |
True |
"type": "application/astra-cluster",
"version": "1.3",
"id": "01eaddc3-75b9-5606-97ae-0aa468b59492",
"name": "GKE-22",
"state": "running",
"stateUnready": [],
"managedState": "unmanaged",
"managedStateUnready": [],
"protectionState": "full",
"protectionStateDetails": [],
"tridentVersion": "21.07.2",
"tridentManagedState": "managed",
"tridentManagedStateDetails": [],
"inUse": "false",
"clusterType": "kubernetes",
"clusterVersion": "1.91.1",
"clusterVersionString": "1.19.1",
"clusterCreationTimestamp": "2020-08-06T12:24:52.256624Z",
"namespaces": [
"kube-system",
"kube-public",
"my-app-1"
"defaultStorageClass": "31c95aba-99d9-4987-b1bb-000dfce5952c",
"cloudID": "548bdc1f-f00e-4a23-a062-83265d224d46",
"credentialID": "6fa2f917-f730-41b8-9c15-17f531843b31",
"location": "europe-west4",
"isMultizonal": "false",
"apiServiceID": "6bf33af2-872a-4553-a891-26b510c3edbe",
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 500, Internal server error
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
"type": "https://astra.netapp.io/problems/65",
"title": "Cluster GET not performed",
"detail": "The cluster GET call didn't perform the lookup operation on the cluster.",
"status": "500"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
type |
string |
True |
title |
string |
True |
detail |
string |
True |
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
