Retrieve a volume for a managed cluster
GET /accounts/{account_id}/topology/v1/managedClusters/{managedCluster_id}/volumes/{volume_id}
Returns the stored Volume API resource in the JSON response body.
account_id
string
path
True
  • example: {{.Account}}
managedCluster_id
string
path
True
ID of the containing managedCluster resource
volume_id
string
path
True
ID of the volume collection to list
Status: 200, Returns the stored Volume API resource in the JSON response body.
type
string
True
  • "application/astra-volume"
version
string
True
  • "1.0"
  • "1.1"
  • "1.2"
id
string
True
name
string
True
JSON string containing the name of the volume. Defined values are:
  • Minimum length: 1
  • Maximum length: 255
state
string
False
JSON string containing a value indicating the operational state of the volume.
size
string
False
JSON string containing the size of the volume.
used
number
False
JSON number containing the number of bytes of quota used by the provisioned volume.
usedPercentage
number
False
JSON number containing the percentage of volume used.
total
number
False
JSON number containing the total bytes of volumes provisioned.
creationToken
string
False
JSON string containing the creation token of the volume. Defined values are:
  • Minimum length: 1
snapshotPossible
string
False
JSON string indicating whether the driver can perform a snapshot of the volume. Defined values are:
  • "true" - Driver can take a snapshot of the volume
  • "false" - Driver cannot take a snapshot of the volume
storageClass
string
False
JSON string containing the storage class for the volume.
  • Defined values are:
  • Minimum length: 1
pvcName
string
False
JSON string containing the PersistentVolumeClaim (PVC) name of the volume.
  • Minimum length: 1
internalName
string
False
JSON string containing the internal name of the volume on the target storage cluster, if available. This name is obtained from the Kubernetes CSI driver.
  • Minimum length: 1
appsUsing
array[string]
True
JSON array of JSON strings, each containing the ID of an application that is using the volume. Defined values are:
  • Conforms to the Astra Identifier Schema
storageBackendID
string
False
JSON string containing the ID of the storage backend that provides the volume. Defined values are:
orchestrator
string
False
JSON string containing the orchestrator for this volume. This will be defined for Astra Data Store volumes. Defined values are:
  • "trident" - Trident has provisioned this volume
  • "vasa" - NetApp VASA Provider has provisioned this volume
  • "other" - The volume has been provisioned manually or the orchestrator is not known
serviceLevel
string
False
JSON string containing the quality of service (QoS) policy defined for this volume at the storage backend level. This will be defined for Astra Data Store volumes.
exportPolicy
string
False
JSON string containing the export policy associated with this volume. This will be defined for Astra Data Store volumes.
nodeId
string
False
JSON string containing the node ID serving the volume. This will be defined for Astra Data Store volumes. Defined values are:
healthState
string
False
JSON string containing a value indicating the health state of the volume. This will be defined for Astra Data Store volumes. Defined values are:
  • "indeterminate" - The health of the resource cannot be determined (for example, due to lack of connectivity)
  • "normal" - The resource has no known issues and can provide services in accordance with the interface specification
  • "warning" - The resource has known issues that do not prevent it providing services in accordance with the interface specification
  • "critical" - The resource has known issues that prevent it from providing services in accordance with the interface specification
healthStateDetails
array[type_astra_stateDetails]
True
JSON array of JSON objects that lists additional details about the current health. If no details are available, this array will be empty.
  • Minimum Items: 0
metadata
type_astra_metadata
True
  • Conforms to the Astra Metadata Schema
  "type": "application/astra-volume",
  "version": "1.2",
  "id": "ab5c9fb8-ddba-526f-8bd3-8d5b72cf4f7f",
  "name": "myVolume",
  "state": "ready",
  "size": "512 GiB",
  "used": 10000000000,
  "usedPercentage": 10,
  "total": 10000000000,
  "creationToken": "ba7d4e0c-6ae3-4b6e-859d-9463e7ca4b4e",
  "snapshotPossible": "true",
  "storageClass": "gold",
  "pvcName": "myVolume",
  "internalName": "trident_sd234234_23424_897d_876sd65w",
  "appsUsing": [],
  "orchestrator": "trident",
  "serviceLevel": "gold",
  "exportPolicy": "astra-vp-default",
  "nodeId": "94d16dd2-9beb-4edb-ab58-1a00e9a90052",
  "healthState": "normal",
  "healthStateDetails": [],
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
Example error response
  "status": "404"
type
string
True
title
string
True
detail
string
True
type_astra_label
name
string
True
value
string
True
type_astra_metadata
labels
array[type_astra_label]
True
creationTimestamp
string
True
string
True
createdBy
string
True
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
