Retrieve a storage backend
GET /accounts/{account_id}/topology/v1/storageBackends/{storageBackend_id}
Returns the stored Storage Backend API resource in the JSON response body.
Name | Type | In | Required | Description |
account_id |
string |
path |
True |
storageBackend_id |
string |
path |
True |
ID of the storageBackend collection to list |
Status: 200, Returns the stored Storage Backend API resource in the JSON response body.
Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
id |
string |
True |
backendName |
string |
True |
JSON string containing a user-specified name for the storage backend. Defined values are:
backendType |
string |
True |
JSON string containing a value indicating the type of the storage backend being represented. Defined values are:
backendVersion |
string |
True |
JSON string containing a value indicating the version of the storage backend being represented. Defined values are:
backendCredentialsName |
string |
True |
JSON string containing a value indicating the name of one or more credential resources used for the storage backend. Allows for credential rotation where multiple credential objects have the same name. Defined values are:
configVersion |
string |
False |
JSON string containing a value indicating the active configuration to be used by the storage backend. Defined values are:
state |
string |
True |
JSON string containing a value indicating the operational state of the storage backend. Defined values are:
stateDesired |
string |
False |
JSON string containing a value indicating the desired operational state of the storage backend. Defined values are:
stateUnready |
array[string] |
True |
JSON array of JSON strings, each indicating a reason why a storage backend is unable to transition to "running", why it has transitioned to "failed" or "unknown", and/or why it is at risk of transitioning to "failed". Defined values are:
managedState |
string |
True |
JSON string containing a value indicating the management state of the storage backend. Defined values are:
managedStateUnready |
array[string] |
True |
JSON array of JSON strings, each indicating a reason why the storage backend is ineligible to be managed. Defined values are:
healthState |
string |
False |
JSON string containing a value indicating the health state of the storage backend. Defined values are:
healthStateUnready |
array[string] |
False |
JSON array of JSON strings, each indicating a reason why a storage backend is not in a normal health state. Defined values are:
protectionState |
string |
True |
JSON string containing a value indicating the protection state of the storage backend. "unknown" for ONTAP. Defined values are:
protectionStateUnready |
array[string] |
True |
JSON array of JSON strings, each indicating a reason why a protection policy is out of conformance. Defined values are:
ontap |
False |
JSON object containing specific information related to ONTAP clusters.
metadata |
True |
"type": "application/astra-storageBackend",
"version": "1.2",
"id": "ad238443-2bc7-54f5-bd7f-5d1668377cd7",
"backendName": "st1-45",
"backendType": "ontap",
"backendVersion": "9.8",
"backendCredentialsName": "st1-45-cred",
"state": "discovered",
"stateUnready": [],
"managedState": "unmanaged",
"managedStateUnready": [],
"protectionState": "unknown",
"protectionStateUnready": [
"Waiting for storage backend discovery"
"ontap": {
"backendManagementIP": "10.193.179.105",
"managementIPs": [
"10.193.188.110",
"10.193.179.105",
"10.193.179.106"
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
ontap
backendManagementIP |
string |
False |
JSON string containing the IP address used to connect to this ONTAP cluster. |
managementIPs |
array[string] |
False |
JSON array of JSON strings containing the list of all possible management IPs used to connect to this ONTAP cluster. This is used to correlate backends detected through Trident and storage backends in Astra.
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
