List all accounts
GET /accounts
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
Name | Type | In | Required | Description |
include |
string |
query |
False |
Indicates which fields should be returned when listing a collection. URL examples: "include=id", "include=id,name" OpenAPI examples: "id" |
limit |
string |
query |
False |
Indicates the maximum number of resources to return when listing a collection. URL examples: "limit=2" OpenAPI examples: "2" |
filter |
string |
query |
False |
Indicates which fields should be matched in order to return a resource when listing a collection. Supported operators are:
URL example: "filter=field%20eq%20%27value%27" OpenAPI examples: "field eq 'value'" |
orderBy |
string |
query |
False |
Indicates the sort order of resource when listing a collection. URL examples: "orderBy=name", "orderBy=name%20desc" OpenAPI examples: "name desc" |
skip |
string |
query |
False |
Indicates the number of resources to skip over when listing a collection. URL examples: "skip=1" OpenAPI examples: "1" |
count |
string |
query |
False |
Indicates if the total number of resources should be returned in the metadata object. URL examples: "count=true" OpenAPI examples: "true" |
continue |
query |
False |
Indicates the token to resume listing from. URL examples: "continue= OpenAPI examples: " |
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
Name | Type | Required | Description |
items |
array[Any of: account_1.0_get_response_body, array[]] |
True |
metadata |
True |
"type": "application/astra-accounts",
"version": "1.0",
"items": [
"type": "application/astra-account",
"version": "1.0",
"id": "70796606-79ba-480b-966c-e4c600fbf622",
"name": "fraught-pines",
"state": "active",
"isEnabled": "true",
"enabledTimestamp": "2020-08-06T12:24:52.256624Z",
"metadata": {
"labels": [],
"creationTimestamp": "2020-08-06T12:24:52.256624Z",
"modificationTimestamp": "2020-08-06T12:24:52.256624Z",
"createdBy": "1723a17e-9fd1-4636-86e1-2ec9e04bce51"
"version": "1.0",
"id": "7976114d-35ec-48a7-ba31-22d8e94a8bb2",
"name": "sad-dino",
"state": "active",
"metadata": {
"labels": [],
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
postalAddress
JSON object containing a collection of JSON strings specifying an address. If this key does not exist, it indicates that an address has not been provided. If this key exists, all six of the contained JSON strings will be present. If you provide nothing, the string will be empty.
addressCountry |
string |
True |
JSON string containing the country name or country code associated with the postal address, as specified in ISO 3166 Alpha-2. Defined values are:
addressLocality |
string |
True |
JSON string containing the locality (for example, city) associated with the postal address. Defined values are:
addressRegion |
string |
True |
JSON string containing the region (for example, state) associated with the postal address. Defined values are:
postalCode |
string |
True |
JSON string containing the postal code associated with the postal address. Defined values are:
streetAddress1 |
string |
True |
JSON string containing the street address associated with the postal address. Defined values are:
streetAddress2 |
string |
False |
JSON string containing optional ancillary street address information, post office box, and more. Defined values are:
accountContact
JSON object containing user contact information to create an owner user at the time of account activation.
firstName |
string |
True |
JSON string containing a user specified long-form first name. Defined values are:
lastName |
string |
True |
JSON string containing a user specified long-form last name. Defined values are:
companyName |
string |
False |
JSON string containing the company name associated with the user. If this key does not exist, it indicates that a company name has not been provided. Defined values are:
string |
True |
JSON strings containing a user specified email address. Defined values are:
phone |
string |
False |
JSON string containing the phone number of the user. If this key does not exist, it indicates that a phone number has not been provided. Defined values are:
postalAddress |
True |
JSON object containing a collection of JSON strings specifying an address. If this key does not exist, it indicates that an address has not been provided. If this key exists, all six of the contained JSON strings will be present. If you provide nothing, the string will be empty. |
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
type |
string |
True |
version |
string |
True |
id |
string |
True |
name |
string |
True |
JSON string containing a name for the account. Defined values are:
state |
string |
True |
JSON string containing a value indicating the operational state of the account. Defined values are:
isEnabled |
string |
True |
JSON string indicating the account is enabled. Defined values are:
enabledTimestamp |
string |
False |
JSON string containing the timestamp indicating when the account was last enabled. If the account has never been enabled, this field is absent. Defined values are:
accountContact |
False |
JSON object containing user contact information to create an owner user at the time of account activation. |
metadata |
True |
type_astra_metadata_list
continue |
string |
False |
count |
number |
False |
labels |
False |
creationTimestamp |
string |
False |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
