Create a new application backup for an app
POST /accounts/{account_id}/k8s/v1/apps/{app_id}/appBackups
Indicates the desired values for the Application Backup API resource to be created.
account_id
string
path
True
  • example: {{.Account}}
app_id
string
path
True
ID of the containing app resource
Request Body
type
string
True
  • "application/astra-appBackup"
version
string
True
  • "1.0"
  • "1.1"
name
string
False
JSON string containing a user-specified name for the backup. If not specified, or when backups are initiated by a schedule, the system will assign a name for the backup. Defined values are:
  • Minimum length: 1
  • Maximum length: 63
  • Conforms to the DNS 1123 Label Schema
bucketID
string
False
JSON string containing an optional bucket ID that indicates where the backup will be stored on create. If not specified, a system-selected bucket is used. If no buckets are available, an error will be returned on create. Defined values are:
  • Conforms to the Astra Identifier Schema
snapshotID
string
False
JSON string containing the snapshot that was used to create the backup. To create the backup, a snapshot ID associated with the application being backed up can be specified on create. If not specified, a new snapshot will be created for the backup. Defined values are:
metadata
type_astra_metadata
False
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels.
Example request
  "type": "application/astra-appBackup",
  "version": "1.1",
  "name": "app-name-245"
Status: 201, Returns the newly created appBackup resource in the JSON response body.
type
string
True
version
string
True
  • "1.0"
  • "1.1"
id
string
True
name
string
True
  • Minimum length: 1
bucketID
string
True
snapshotID
string
False
scheduleID
string
False
JSON string containing an optional schedule ID that indicates that the backup was triggered by a schedule and which schedule triggered the backup. Only present for backups initiated by a schedule. Defined values are:
state
string
True
JSON string containing a value indicating the operational state of the backup. Defined values are:
  • "pending" - The application backup is scheduled for discovery
  • "discovering" - The application backup is in the process of being discovered
  • "running" - The application backup is running normally
  • "completed" - The application backup has completed successfully
  • "failed" - The application backup is in a permanent failure state
  • "removed" - The application backup is not currently accessible
  • "unknown" - The application backup state cannot be determined
stateUnready
array[string]
True
JSON array of JSON strings, each indicating a reason why an application backup is unable to transition to "running", or why it has transitioned to "failed" or "removed". Defined values are:
  • Minimum length: 1
  • Maximum length: 127
hookState
string
False
JSON string containing a value indicating the state of any execution hooks run as part of snapshot. Defined values are:
  • "failed" - One or more execution hooks have failed
  • "success" - There were zero or more applicable hooks and all were successful
hookStateDetails
array[type_astra_stateDetails]
False
JSON array of JSON objects which lists additional details about why "hookState" transitioned into "failed". If no details are available, this array will be empty.
  • Minimum items: 0
backupCreationTimestamp
string
False
JSON string containing a timestamp indicating when the backup was taken. Defined values are:
  • Conforms to the ISO-8601 Date Time Schema
totalBytes
number
False
JSON number containing the total number of bytes in the backup.
bytesDone
number
False
JSON number containing the number of bytes backed up for a running backup. When the backup is completed, it matches with the totalBytes field.
percentDone
number
False
JSON number containing the percentage complete for a running backup. When the backup is completed, it is set to "100".
metadata
type_astra_metadata
True
  "version": "1.1",
  "id": "54fe651d-3d3b-5fa8-b85c-5db757885ff3",
  "name": "app-name-245",
  "bucketID": "0afbe357-a717-4c7a-8b3d-d0368959c8de",
  "scheduleID": "1fe83650-9b3c-41ef-bb25-a2910c19c33e",
  "state": "pending",
  "stateUnready": [],
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidFields
array[invalidFields]
False
List of invalid request body fields
  "status": "400"
Status: 409, Conflict
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "409"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "403"
Status: 500, Internal server error
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "type": "https://astra.netapp.io/problems/94",
  "title": "Backup not created",
  "detail": "The backup wasn't created because of an internal server issue.",
  "status": "500"
Status: 404, Not found
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
Example error response
  "status": "404"
type_astra_label
name
string
True
value
string
True
type_astra_metadata
labels
array[type_astra_label]
True
creationTimestamp
string
True
string
True
createdBy
string
True
modifiedBy
string
False
type
string
True
title
string
True
detail
string
True
invalidParams
name
string
True
reason
string
True
invalidFields
name
string
True
Name of the invalid request body field
reason
string
True
Reason why the request body field is invalid
