Create a new execution hook override resource for an app
POST /accounts/{account_id}/k8s/v1/apps/{app_id}/executionHookOverrides
Indicates the desired values for the Execution Hook Override API resource to be created.
Name | Type | In | Required | Description |
account_id |
string |
path |
True |
app_id |
string |
path |
True |
ID of the containing app resource |
Request Body
Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
executionHookID |
string |
True |
JSON string containing the ID of an execution hook. Defined values are:
enabled |
string |
True |
JSON string that indicates whether the execution hook is enabled for the specified application. Defined values are:
metadata |
False |
Example request
"type": "application/astra-executionHookOverride",
"version": "1.0",
"executionHookID": "eb863cc6-0d9a-454d-8ef7-81b7cac91929",
"enabled": "false"
Status: 201, Returns the newly created executionHookOverride resource in the JSON response body.
type |
string |
True |
version |
string |
True |
id |
string |
True |
executionHookID |
string |
True |
enabled |
string |
True |
appID |
string |
True |
JSON string containing the associated ID of the application with which the override is linked. Defined values are:
metadata |
True |
"version": "1.0",
"id": "c11af802-5e53-5897-8cd9-2de730494be3",
"enabled": "false",
"appID": "4b43c2f7-bffa-4f60-b595-d98a05b64bc9",
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
array[invalidFields] |
False |
List of invalid request body fields |
"status": "400"
Status: 409, Conflict
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
False |
"status": "409"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
invalidFields
name |
string |
True |
Name of the invalid request body field |
reason |
string |
True |
Reason why the request body field is invalid |
