Astra Automation
Modify a certificate
PUT /accounts/{account_id}/core/v1/certificates/{certificate_id}
Replaces the entire stored resource with the supplied JSON request body.
Side Effects
  • An updated CA certificate will be updated in the trust store.
  • If an existing trusted CA certificate becomes untrusted, it will be removed from the trust store.
  • If a certificate body is updated ("cert" field), the "isSelfSigned" indicator must be included to indicate the state of the new certificate. If the "isSelfSigned" indicator is not included in this case, the value will be set to "false".
  • If an update does not modify the certificate body ("cert" field), the "isSelfSigned" indicator is optional and the existing value will be retained if not provided.
account_id
string
path
True
  • example: {{.Account}}
certificate_id
string
path
True
ID of the certificate collection to list
Request Body
Side Effects
type
string
True
  • "application/astra-certificate"
version
string
True
  • "1.0"
id
string
False
certUse
string
False
JSON string indicating the use of the certificate. If not specified, defaults to "rootCA". Defined values are:
  • "rootCA" - The certificate is a certificate authority (CA) certificate used to trust any certificate signed by that CA.
  • "intermediateCA" - The certificate is an intermediate CA certificate issued by a root CA.
cert
string
False
JSON string containing a Base64 encoded PKCS-11 formatted certificate (PEM). Defined values are:
  • Conforms to the base64 Encoded Data Schema
cn
string
False
JSON string containing a common name extracted from the certificate. Defined values are:
  • Minimum length: 1
  • Maximum length: 511
expiryTimestamp
string
False
JSON string containing a timestamp indicating when the certificate expires. Defined values are:
  • Conforms to the ISO-8601 Date Time Schema
isSelfSigned
string
False
JSON string indicating whether the certificate is self-signed. If not provided on create, the value defaults to "false". On update:
  • If the value is provided, that value will be used.
  • If the value is not provided and the "cert" field is included in the update, the value will be set to "false".
  • If the value is not provided and the "cert" field is not included in the update, the existing value will be retained. Defined values are:
  • "true" - The certificate is self-signed.
  • "false" - The certificate is not self-signed.
trustState
string
False
JSON string containing one of a set of enumerated values indicating whether the certificate is trusted. Defined values are:
  • "untrusted" - The certificate is not trusted.
  • "trusted" - The certificate is marked as trusted.
  • "expired" - The certificate is expired, so is neither trusted or not trusted.
trustStateTransitions
array[type_astra_stateTransitions]
False
JSON array of JSON objects, each representing the set of permitted state transitions from a given defined state. Each JSON object contains the fields "from" and "to", where the "from" value is the name of a state, and the "to" value is an array of permitted destination states.
trustStateDesired
string
False
JSON string containing a value indicating whether the certificate is trusted. If not specified on create, the default value is "trusted". Defined values are:
trustStateDetails
array[type_astra_stateDetails]
False
JSON array of JSON objects that lists additional details about the trust state of the certificate. If no details are available, this array will be empty.
  • Minimum Items: 0
metadata
type_astra_metadata_update
False
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
Example request
  "type": "application/astra-certificate",
  "version": "1.0",
  "trustStateDesired": "trusted"
Status: 204, Indicates if the certificate resource was updated.
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidFields
array[invalidFields]
False
List of invalid request body fields
  "status": "400"
Status: 409, Conflict
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidFields
False
  "status": "409"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
Example error response
  "status": "404"
from
string
True
to
array[string]
True
type
string
True
title
string
True
detail
string
True
type_astra_label
name
string
True
value
string
True
labels
array[type_astra_label]
False
creationTimestamp
string
False
modificationTimestamp
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
invalidFields
name
string
True
Name of the invalid request body field
reason
string
True
Reason why the request body field is invalid
