Astra Automation
Modify an execution hook
PUT /accounts/{account_id}/core/v1/executionHooks/{executionHook_id}
Replaces the entire stored resource with the supplied JSON request body while preserving key values that are not user-modifiable.
Side Effects
  • Updating an existing execution hook will impact any future actions of applications that use the updated execution hook.
account_id
string
path
True
  • example: {{.Account}}
executionHook_id
string
path
True
ID of the executionHook collection to list
Request Body
Side Effects
type
string
True
  • "application/astra-executionHook"
version
string
True
  • "1.0"
  • "1.1"
  • "1.2"
id
string
False
name
string
False
JSON string containing a user-specified name for the resource. Defined values are:
  • Minimum length: 1
  • Maximum length: 63 Name must be unique across all execution hook resources.
hookType
string
False
JSON string defining the hook type. Defined values are:
  • "netapp" - NetApp provided execution hook.
  • "custom" - Tied to a specific app ID. Execution hook resources with hookType "netapp" are read only.
matchingCriteria
array[matchingCriteria]
False
JSON array of JSON objects describing the match criteria for the execution hook. When multiple matchingCriteria are specified a logical AND is applied to criteria. Defined values are:
  • Minimum items: 0
  • Maximum items: 10
action
string
False
JSON string indicating which action the execution hook will run assuming the match criteria are met. Defined values are:
  • "snapshot"
  • "backup"
  • "restore"
stage
string
False
JSON string indicating the stage during the action that the hook will be executed. Defined values are:
  • "pre" - The execution hook will be run before the specified action.
  • "post" - The execution hook will be run after the specified action. Values for action "snapshot" are "pre" and "post". Values for action "backup" are "pre" and "post". Value for action "restore" is "post".
hookSourceID
string
False
JSON string containing the hook source ID that is run through this execution hook. Defined values are:
  • Conforms to the Astra Identifier Schema
arguments
array[string]
False
JSON array of JSON strings for the arguments to the source. Defined values are:
  • Minimum items: 0
  • Maximum items: 16
  • Minimum length: 0
  • Maximum length: 127
appID
string
False
JSON string containing the associated ID of the application that this hook is linked to. In essence, other matching criteria, if set. Defined values are:
enabled
string
False
JSON string that indicates if the execution hook is enabled. Defined values are:
  • "true" - The execution hook is enabled and will be run as specified.
  • "false" - The execution hook is disabled and will never run. The default value is "true".
description
string
False
JSON string containing a user-specified description for the hook source. Defined values are:
  • Minimum length: 0
  • Maximum length: 511
metadata
type_astra_metadata_update
False
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
Example request
  "type": "application/astra-executionHook",
  "version": "1.2",
  "arguments": [
    "freeze",
    "10"
JSON
Status: 204, Indicates if the executionHook resource was updated.
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "401"
JSON
Status: 400, Bad request
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidFields
array[invalidFields]
False
List of invalid request body fields
  "status": "400"
JSON
Status: 409, Conflict
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidFields
False
  "status": "409"
JSON
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "403"
JSON
Status: 404, Not found
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
Example error response
  "type": "https://astra.netapp.io/problems/1",
  "title": "Resource not found",
  "detail": "The resource specified in the request URI wasn't found.",
  "status": "404"
JSON
matchingCriteria
type
string
False
JSON string identifying the match criteria type.
value
string
False
JSON string containing a regex to match for the given match type. Regex syntax: https://github.com/google/re2/wiki/Syntax
type_astra_label
name
string
True
value
string
True
labels
array[type_astra_label]
False
creationTimestamp
string
False
modificationTimestamp
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
invalidFields
name
string
True
Name of the invalid request body field
reason
string
True
Reason why the request body field is invalid
