Modify a license
PUT /accounts/{account_id}/core/v1/licenses/{license_id}
Replaces the entire stored resource with the supplied JSON request body while preserving key values that are not user-modifiable.
Side Effects
Entitlements are recalculated to add or merge the license entitlements visible through the Entitlement API.
Name | Type | In | Required | Description |
account_id |
string |
path |
True |
license_id |
string |
path |
True |
ID of the license collection to list |
Request Body
Side Effects
Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
id |
string |
False |
allocation |
string |
False |
JSON string containing an ID indicating what the license is allocated to. Only present when the license is allocated. For Astra Control Center licenses, this field must be populated with the account ID and must match the account ID specified in the POST URI. Defined values are:
hostID |
string |
False |
JSON string containing a host identifier that a license is bound to. Only present if the license is host-locked. Defined values are:
deviceCredentialID |
string |
False |
JSON string containing the identifier of the deviceCredential associated from the Credential API. Only present for Astra Data Store licenses. Defined value are:
isEvaluation |
string |
False |
JSON string indicating whether the license is an evaluation license. Defined values are:
licenseProtocol |
string |
False |
JSON string containing the license protocol extracted from the license. Defined values are:
licenseText |
string |
False |
JSON string containing a base64 encoded representation of the license JSON as obtained from the NetApp license system. This must be provided in the original byte-level order to allow signature verification. Defined values are:
validFromTimestamp |
string |
False |
JSON string containing a timestamp indicating when the license becomes valid. Defined values are:
validUntilTimestamp |
string |
False |
JSON string containing a timestamp indicating when the license is no longer valid. Defined values are:
product |
string |
False |
JSON string containing the product string extracted from the license. Defined values are:
productVersion |
string |
False |
JSON string containing the version string extracted from the license. Defined values are:
productSN |
string |
False |
JSON string containing the serial number string extracted from the license. Defined values are:
features |
string |
False |
JSON string containing the package value extracted from the license. Defined values are:
capacity |
string |
False |
JSON string containing the capacity extracted from the license. |
capacity2 |
string |
False |
JSON string containing the secondary capacity extracted from the license. |
addons |
array[addons] |
False |
JSON array of JSON objects containing the list of add-ons from the license. An add-on is a change in license occurring at a potential future date. |
metadata |
False |
Example request
"type": "application/astra-license",
"version": "1.0",
"allocation": "4185d09b-6687-4801-a832-c005a9d94f41",
"licenseText": "ewogICAic3RhdHVzUmVzcCI6ewogMTYwNzAwIgp9"
Status: 204, Indicates if the license resource was updated.
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
array[invalidFields] |
False |
List of invalid request body fields |
"status": "400"
Status: 409, Conflict
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
False |
"status": "409"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
Example error response
"type": "https://astra.netapp.io/problems/1",
"title": "Resource not found",
"detail": "The resource specified in the request URI wasn't found.",
"status": "404"
addons
startDate |
string |
False |
JSON string containing a timestamp indicating when this add-on becomes valid. Defined values are:
endDate |
string |
False |
JSON string containing a timestamp indicating when this add-on is no longer valid. Defined values are:
features |
string |
False |
JSON string containing the list of features associated with this add-on. Defined values are:
capacity |
string |
False |
JSON string containing the capacity extracted from the add-on. Defined values are:
licenseProtocol |
string |
False |
JSON string containing the license protocol associated with this add-on. Defined values are:
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
invalidFields
name |
string |
True |
Name of the invalid request body field |
reason |
string |
True |
Reason why the request body field is invalid |
