Modify a schedule
PUT /accounts/{account_id}/k8s/v1/apps/{app_id}/schedules/{schedule_id}
Replaces the entire stored resource with the supplied JSON request body while preserving key values that are not user-modifiable.
Name | Type | In | Required | Description |
account_id |
string |
path |
True |
app_id |
string |
path |
True |
ID of the containing app resource |
schedule_id |
string |
path |
True |
ID of the schedule collection to list |
Request Body
Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
id |
string |
False |
name |
string |
False |
JSON string containing a name of the schedule. Defined values are:
enabled |
string |
False |
JSON string indicating if a schedule is active. Defined values are:
granularity |
string |
False |
JSON string indicating the granularity of the schedule. Defined values are:
minute |
string |
False |
JSON string containing a numeric value indicating the minute of the hour (0 - 59) to execute the schedule. Defined values are:
hour |
string |
False |
JSON string containing a numeric value indicating the hour of the day (0 - 23) to execute the schedule. Defined values are:
dayOfWeek |
string |
False |
JSON string containing a numeric value indicating the day of the week (0-7) to execute the schedule. Defined values are:
dayOfMonth |
string |
False |
JSON string containing a numeric value indicating the day of the month (1-31) to execute the schedule. Defined values are:
recurrenceRule |
string |
False |
JSON string containing an RFC-5545 Section 3.8.5.3. Recurrence Rule. For the DTSTART parameter, only UTC timestamps (denoted by the "Z" suffix) are supported, and only timestamps before the current time are supported. For the RECUR rule parts, "FREQ" and "INTERVAL" are the only rule parts supported. For the FREQ rule part, "MINUTELY" and "HOURLY" are the only values supported. This field is only present if granularity is set to "custom". |
snapshotRetention |
string |
True |
JSON string containing a positive numeric value indicating how many snapshots to retain. Zero indicates that snapshots should be deleted after taking a backup. Defined values are:
backupRetention |
string |
True |
JSON string containing a positive numeric value indicating how many backups to retain. Zero indicates that no backups should be created. Defined values are:
bucketID |
string |
False |
JSON string containing an optional bucket ID indicating where the backup must be stored on create. If not specified, a system-selected bucket will be used. Defined values are:
replicate |
string |
False |
JSON string indicating if the schedule should trigger AppMirror replication for each snapshot. Only takes effect if the application has an AppMirror relationship defined. Defined values are:
metadata |
False |
Example request
"type": "application/astra-schedule",
"version": "1.3",
"granularity": "daily",
"minute": "0",
"hour": "0",
"snapshotRetention": "12",
"backupRetention": "12"
Status: 204, Indicates if the schedule resource was updated.
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
array[invalidFields] |
False |
List of invalid request body fields |
"status": "400"
Status: 409, Conflict
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
False |
"status": "409"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
False |
status |
string |
True |
correlationID |
string |
False |
Example error response
"type": "https://astra.netapp.io/problems/1",
"title": "Resource not found",
"detail": "The resource specified in the request URI wasn't found.",
"status": "404"
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
invalidFields
name |
string |
True |
Name of the invalid request body field |
reason |
string |
True |
Reason why the request body field is invalid |
