Modify a cloud
PUT /accounts/{account_id}/topology/v1/clouds/{cloud_id}
Replaces the entire stored resource with the supplied JSON request body while preserving key values that are not user-modifiable.
Side Effects
  • An update will trigger a rediscovery of SAs and clusters.
account_id
string
path
True
  • example: {{.Account}}
cloud_id
string
path
True
ID of the cloud collection to list
Request Body
Side Effects
type
string
True
  • "application/astra-cloud"
version
string
True
  • "1.0"
  • "1.1"
id
string
False
name
string
False
JSON string containing the name of the cloud. Defined values are:
  • Minimum length: 1
  • Maximum length: 63
  • This string is internally validated to prevent XSS, Unicode, directory traversal, and SQL-injection attacks
state
string
False
JSON string containing a value indicating the operational state of the cloud. Defined values are:
  • "pending" - The cloud is scheduled for discovery
  • "discovering" - The cloud is in the process of being discovered
  • "provisioning" - The cloud is in the process of being provisioned
  • "running" - The cloud is running normally
  • "failed" - The cloud is in a permanent failure state
  • "removed" - The cloud is not currently accessible
  • "unknown" - The cloud state cannot be determined
stateUnready
array[string]
False
JSON array of JSON strings, each indicating a reason why a cloud is unable to transition to "running" or why it has transitioned to "failed". Defined values are:
  • Minimum length: 1
  • Maximum length: 127
cloudType
string
False
JSON string containing a value indicating the type of cloud. Defined values are:
  • "gcp" - The cloud is provided by Google
  • "azure" - The cloud is provided by Microsoft
  • "aws" - The cloud is provided by Amazon
  • "private" - The cloud is customer managed
credentialID
string
False
JSON string containing a value indicating the ID of the credential that contains the service account for the cloud. This is required for cloudType "gcp", "azure" and "aws". Defined values are:
  • Conforms to the Astra Identifier Schema
defaultBucketID
string
False
JSON string containing the ID of a bucket that is to be used by default when creating backups for applications within the cloud. This is required when cloning applications across clusters and is used as a default if a bucket is not specified when creating backups and schedules. Defined values are:
metadata
type_astra_metadata_update
False
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
Example request
  "type": "application/astra-cloud",
  "version": "1.1"
Status: 204, Indicates if the cloud resource was updated.
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidFields
array[invalidFields]
False
List of invalid request body fields
  "status": "400"
Status: 409, Conflict
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "409"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
Example error response
  "type": "https://astra.netapp.io/problems/1",
  "title": "Resource not found",
  "detail": "The resource specified in the request URI wasn't found.",
  "status": "404"
type_astra_label
name
string
True
value
string
True
labels
array[type_astra_label]
False
creationTimestamp
string
False
modificationTimestamp
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
invalidFields
name
string
True
Name of the invalid request body field
reason
string
True
Reason why the request body field is invalid
