Astra Automation
Delete a certificate
Deletes a certificate. Use this endpoint to remove a specific Certificate API resource when it is no longer needed.
HTTP method and endpoint
DELETE /accounts/{account_id}/core/v1/certificates/{certificate_id}
Usage notes
Removes the specified Certificate API resource.
account_id
string
path
True
  • example: {{.Account}}
certificate_id
string
path
True
ID of the certificate collection to list
Status: 204, Indicates if the certificate resource was deleted.
Status: 503, Service unavailable
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "type": "https://astra.netapp.io/problems/41",
  "title": "Service not ready",
  "detail": "Currently, the service can't respond to this request.",
  "status": "503"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "status": "403"
