Astra Automation
Delete a group
Deletes the specified group resource. Use this to remove a group along with its associated role bindings from the system.
HTTP method and endpoint
DELETE /accounts/{account_id}/core/v1/groups/{group_id}
Usage notes
Removes the specified Group API resource.
Side Effects
  • The following resources associated with the group are deleted:
  • Role bindings referring to the group
account_id
string
path
True
  • example: {{.Account}}
group_id
string
path
True
ID of the group collection to list
Status: 204, Indicates if the group resource was deleted.
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "type": "https://astra.netapp.io/problems/12",
  "title": "Invalid headers",
  "detail": "The request headers are invalid.",
  "status": "400"
Status: 500, Internal server error
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "type": "https://astra.netapp.io/problems/34",
  "title": "Internal server error",
  "detail": "The server was unable to process this request.",
  "status": "500"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "status": "403"
invalidParams
name
string
True
reason
string
True
