Astra Automation
Delete a token for a user in a group
Deletes a token for a user in a group. This action removes the specified token API resource and its associated credential from the service.
HTTP method and endpoint
DELETE /accounts/{account_id}/core/v1/groups/{group_id}/users/{user_id}/tokens/{token_id}
Usage notes
Removes the specified Token API resource.
Side Effects
  • The corresponding API token credential is removed from the credential service as a side effect.
account_id
string
path
True
  • example: {{.Account}}
group_id
string
path
True
ID of the containing group resource
user_id
string
path
True
ID of the containing user resource
token_id
string
path
True
ID of the token collection to list
Status: 204, Indicates if the token resource was deleted.
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "type": "https://astra.netapp.io/problems/1",
  "title": "Resource not found",
  "detail": "The resource specified in the request URI wasn't found.",
  "status": "404"
invalidParams
name
string
True
reason
string
True
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
