Delete a token
Deletes a specified token, removing its associated credential from the credential service.
HTTP method and endpoint
DELETE /accounts/{account_id}/core/v1/users/{user_id}/tokens/{token_id}
Usage notes
Removes the specified Token API resource.
Side Effects
The corresponding API token credential is removed from the credential service as a side effect.
account_id |
string |
path |
True |
user_id |
string |
path |
True |
ID of the containing user resource |
token_id |
string |
path |
True |
ID of the token collection to list |
Status: 204, Indicates if the token resource was deleted.
Status: 401, Unauthorized
| Name | Type | Required | Description |
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"type": "https://astra.netapp.io/problems/1",
"title": "Resource not found",
"detail": "The resource specified in the request URI wasn't found.",
"status": "404"
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
