Astra Automation
Delete an AppMirror resource for an app
Deletes an AppMirror resource for an app, initiating the removal of associated resources on both the source and destination clusters based on the current relationship state.
HTTP method and endpoint
DELETE /accounts/{account_id}/k8s/v1/apps/{app_id}/appMirrors/{appMirror_id}
Usage notes
Removes the specified AppMirror API resource. Starts a process to asynchronously remove the AppMirror resource, along with any resources on the source and destination clusters that were created as a result of the AppMirror relationship. The resources removed are dependent on the state of the relationship at the time of deletion.
Side Effects
  • The stateDesired field is set to "deleted".
  • The state field is set to "deleting".
  • If state is "established", the TridentMirrorRelationships and PersistentVolumeClaims created by the AppMirror relationship will be deleted.
  • If state is "failedOver", the TridentMirrorRelationships created by the AppMirror relationship will be deleted and the PersistentVolumeClaims in the destination application will be left in place.
  • When the asynchronous delete operation is completed, the AppMirror API resource will be removed from both the source and destination applications.
account_id
string
path
True
  • example: {{.Account}}
app_id
string
path
True
ID of the containing app resource
appMirror_id
string
path
True
ID of the appMirror collection to list
Status: 204, Indicates if the appMirror resource was deleted.
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "type": "https://astra.netapp.io/problems/1",
  "title": "Resource not found",
  "detail": "The resource specified in the request URI wasn't found.",
  "status": "404"
invalidParams
name
string
True
reason
string
True
