Astra Automation
Delete a storage backend
Deletes a storage backend. Use this action to remove all associated backendConfig and backendNode resources from the system.
HTTP method and endpoint
DELETE /accounts/{account_id}/topology/v1/storageBackends/{storageBackend_id}
Usage notes
Removes the specified Storage Backend API resource.
Side Effects
  • All backendConfig resources associated with the storage backend are removed.
  • All backendNode resources associated with the storage backend are removed.
  • The storage backend might be removed.
account_id
string
path
True
  • example: {{.Account}}
storageBackend_id
string
path
True
ID of the storageBackend collection to list
Status: 204, Indicates if the storageBackend resource was deleted.
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "type": "https://astra.netapp.io/problems/1",
  "title": "Resource not found",
  "detail": "The resource specified in the request URI wasn't found.",
  "status": "404"
invalidParams
name
string
True
reason
string
True
