Astra Automation
Astra API (ACS) execution hook endpoints
Create and manage execution hooks for your applications. Each hook holds additional configuration and refers to a hook source.
The Execution Hook API enables simple management of execution hooks. Execution hooks contain additional configuration and references to a hook source resource.
