List all ASUP resources
Retrieves a list of ASUP resources, providing detailed information for each resource in the collection. You can specify individual fields to tailor the output to your needs.
HTTP method and endpoint
GET /accounts/{account_id}/core/v1/asups
Usage notes
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
account_id |
string |
path |
True |
include |
string |
query |
False |
Indicates which fields should be returned when listing a collection. URL examples: "include=id", "include=id,name" OpenAPI examples: "id" |
limit |
string |
query |
False |
Indicates the maximum number of resources to return when listing a collection. URL examples: "limit=2" OpenAPI examples: "2" |
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
| Name | Type | Required | Description |
items |
array[Any of: asup_1.0_get_response_body, array[]] |
True |
metadata |
True |
"type": "application/astra-asups",
"version": "1.0",
"items": [
"type": "application/astra-asup",
"version": "1.0",
"id": "80796606-79ba-480b-966c-e4c600fbf623",
"creationState": "completed",
"creationStateDetails": [],
"upload": "true",
"uploadState": "running",
"uploadStateDetails": [],
"triggerType": "manual",
"dataWindowStart": "2020-08-05T12:24:00.000000Z",
"dataWindowEnd": "2020-08-06T12:24:52.000000Z",
"metadata": {
"labels": [],
"creationTimestamp": "2020-08-06T12:24:52.256624Z",
"modificationTimestamp": "2020-08-06T12:24:52.256624Z",
"createdBy": "1b32a508-cc6f-4f1b-809f-c42fd91b4848"
"version": "1.0",
"id": "6503131d-8b36-4434-b34f-73661ae8100b",
"upload": "true",
"uploadState": "completed",
"triggerType": "scheduled",
"dataWindowStart": "2020-08-04T13:30:00.000000Z",
"dataWindowEnd": "2020-08-05T13:30:00.000000Z",
"metadata": {
"labels": [],
"creationTimestamp": "2020-08-05T13:30:00.012321Z",
"modificationTimestamp": "2020-08-05T13:30:00.012321Z",
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
type_astra_stateDetail
type |
string |
True |
title |
string |
True |
detail |
string |
True |
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels.
labels |
array[type_astra_label] |
True |
creationTimestamp |
string |
True |
modificationTimestamp |
string |
True |
createdBy |
string |
True |
modifiedBy |
string |
False |
type |
string |
True |
version |
string |
True |
id |
string |
True |
creationState |
string |
True |
JSON string containing a value indicating the creation state of the AutoSupport bundle. For "completed" and "partial" states, the bundle can be downloaded by performing a GET of the resource URI with an Accept header containing "/" or "application/gzip". Defined values are:
creationStateDetails |
array[type_astra_stateDetail] |
True |
JSON array of JSON objects that lists additional details about why "creationState" transitioned into "partial" or "failed". If no details are available, this array will be empty.
upload |
string |
True |
JSON string containing a value indicating whether to upload the AutoSupport bundle after successful creation. Defined values are:
uploadState |
string |
False |
JSON string containing a value that indicates the state of the AutoSupport bundle upload if it was requested. Defined values are:
uploadStateDetails |
False |
JSON array of JSON objects that lists additional details about why "uploadState" transitioned into "failed". If no details are available, this array will be empty.
triggerType |
string |
True |
JSON string containing a value that indicates what triggered the creation of the ASUP resource. Defined values are:
dataWindowStart |
string |
True |
JSON string containing a timestamp indicating the start time of the AutoSupport bundle data collection window. Defaults to 24 hours before the "dataWindowEnd" key value. Must occur before the "dataWindowEnd" key value. Maximum is 7 days before the current time of the request. Defined values are:
dataWindowEnd |
string |
True |
JSON string containing a timestamp indicating the end time of the AutoSupport bundle data collection window. Defaults to the current time of the request. Defined values are:
metadata |
True |
type_astra_metadata_list
continue |
string |
False |
count |
number |
False |
labels |
False |
creationTimestamp |
string |
False |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
