Retrieve a certificate
Retrieves a certificate to provide the stored Certificate API resource details in the response.
HTTP method and endpoint
GET /accounts/{account_id}/core/v1/certificates/{certificate_id}
Usage notes
Returns the stored Certificate API resource in the JSON response body.
account_id |
string |
path |
True |
certificate_id |
string |
path |
True |
ID of the certificate collection to list |
Status: 200, Returns the stored Certificate API resource in the JSON response body.
| Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
id |
string |
True |
certUse |
string |
True |
JSON string indicating the use of the certificate. If not specified, defaults to "rootCA". Defined values are:
cert |
string |
True |
JSON string containing a base64 encoded PKCS-11 formatted certificate (PEM). Defined values are:
cn |
string |
True |
JSON string containing a common name extracted from the certificate. Defined values are:
expiryTimestamp |
string |
True |
JSON string containing a timestamp indicating when the certificate expires. Defined values are:
isSelfSigned |
string |
True |
JSON string indicating whether the certificate is self-signed. If not provided on create, the value defaults to "false". On update:
trustState |
string |
True |
JSON string containing one of a set of enumerated values indicating whether the certificate is trusted. Defined values are:
trustStateTransitions |
array[type_astra_stateTransition] |
True |
JSON array of JSON objects, each representing the set of permitted state transitions from a given defined state. Each JSON object contains the fields "from" and "to", where the "from" value is the name of a state, and the "to" value is an array of permitted destination states. |
trustStateDesired |
string |
False |
JSON string containing a value indicating whether the certificate is trusted. If not specified on create, the default value is "trusted". Defined values are:
trustStateDetails |
array[type_astra_stateDetail] |
True |
JSON array of JSON objects that lists additional details about the trust state of the certificate. If no details are available, this array will be empty.
metadata |
True |
"type": "application/astra-certificate",
"version": "1.1",
"id": "a26cbed4-2183-58ce-aa19-e37ca8b0531a",
"certUse": "rootCA",
"cert": "LS0tLS1CRUdJTiBDRVJUSUZJQ0FURS0tLS0tCk1JSUZyVENDQTVXZ0F3MVJHbnFGbUJSSWRyV1kwPQotLS0tLUVORCBDRVJUSUZJQ0FURS0tLS0t",
"cn": "vcenter.example.com",
"expiryTimestamp": "2022-03-23T16:48:38.5233461Z",
"isSelfSigned": "true",
"trustState": "untrusted",
"trustStateTransitions": [
"from": "untrusted",
"to": [
"trusted"
"from": "trusted",
"to": [
"untrusted"
"trustStateDetails": [],
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 503, Service unavailable
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"type": "https://astra.netapp.io/problems/41",
"title": "Service not ready",
"detail": "Currently, the service can't respond to this request.",
"status": "503"
Status: 409, Conflict
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"type": "https://astra.netapp.io/problems/164",
"title": "Requested resource in unexpected state",
"detail": "The requested resource can't be returned because it isn't in the expected state. Wait for the conflict to be resolved and retry the request.",
"status": "409"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
from |
string |
True |
to |
array[string] |
True |
type |
string |
True |
title |
string |
True |
detail |
string |
True |
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
