List all entitlements
Retrieves a list of entitlements, providing information on all matching resources in the collection. Use this to access specific resource details based on your request criteria.
HTTP method and endpoint
GET /accounts/{account_id}/core/v1/entitlements
Usage notes
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
account_id |
string |
path |
True |
include |
string |
query |
False |
Indicates which fields should be returned when listing a collection. URL examples: "include=id", "include=id,name" OpenAPI examples: "id"
limit |
string |
query |
False |
Indicates the maximum number of resources to return when listing a collection. URL examples: "limit=2" OpenAPI examples: "2" |
filter |
string |
query |
False |
Indicates which fields should be matched in order to return a resource when listing a collection. Supported operators are:
URL example: "filter=field%20eq%20%27value%27" OpenAPI examples: "field eq 'value'" |
orderBy |
string |
query |
False |
Indicates the sort order of resource when listing a collection. URL examples: "orderBy=name", "orderBy=name%20desc" OpenAPI examples: "name desc" |
skip |
string |
query |
False |
Indicates the number of resources to skip over when listing a collection. URL examples: "skip=1" OpenAPI examples: "1" |
count |
string |
query |
False |
Indicates if the total number of resources should be returned in the metadata object. URL examples: "count=true" OpenAPI examples: "true" |
continue |
query |
False |
Indicates the token to resume listing from. URL examples: "continue= OpenAPI examples: " |
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
| Name | Type | Required | Description |
items |
array[Any of: entitlement_1.0_get_response_body, array[]] |
True |
metadata |
True |
"type": "application/astra-entitlements",
"version": "1.0",
"items": [
"Astra SDS",
"capacity",
"2",
null
"Astra Enterprise",
"clusters",
"100",
"5e9fe8f7-4c54-441c-ac94-fd8451f9ca38"
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata
Conforms to the Astra Metadata Schema
labels |
array[type_astra_label] |
True |
creationTimestamp |
string |
True |
modificationTimestamp |
string |
True |
createdBy |
string |
True |
modifiedBy |
string |
False |
type |
string |
True |
version |
string |
True |
id |
string |
True |
allocation |
string |
False |
JSON string containing the ID of the object that the entitlement is allocated to. Only present when the entitlement is allocated. String contents not validated by the schema. |
product |
string |
False |
JSON string containing the product string extracted from the license or subscription. String contents not validated by the schema. |
productVersion |
string |
False |
JSON string containing the version string extracted from the license or subscription. String contents not validated by the schema. |
entitlementType |
string |
True |
JSON string containing the type of the entitlement. This is extracted from the license or subscription. String contents not validated by the schema. |
entitlementValue |
string |
True |
JSON string containing the capacity associated with the entitlement. String contents not validated by the schema. |
entitlementConsumption |
string |
False |
JSON string containing the amount of the capacity associated with the entitlement that is currently in use. String contents not validated by the schema. |
sourceLicense |
string |
False |
JSON string containing the license object ID that the entitlement is sourced from. Defined values are:
sourceSubscription |
string |
False |
JSON string containing the ID of the subscription object that the entitlement is sourced from. Defined values are:
validFromTimestamp |
string |
False |
JSON string containing a timestamp indicating when the entitlement becomes valid. Defined values are:
validUntilTimestamp |
string |
False |
JSON string containing a timestamp indicating when the entitlement is no longer valid. Defined values are:
metadata |
True |
type_astra_metadata_list
continue |
string |
False |
count |
number |
False |
labels |
False |
creationTimestamp |
string |
False |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
