Retrieve an execution hook
Retrieves an execution hook, providing stored resource details and matching container and image information based on current criteria.
HTTP method and endpoint
GET /accounts/{account_id}/core/v1/executionHooks/{executionHook_id}
Usage notes
Returns the stored Execution Hook API resource in the JSON response body. Also populates matchingContainers and matchingImages based on the current matchingCriteria and the defined app.
account_id |
string |
path |
True |
executionHook_id |
string |
path |
True |
ID of the executionHook collection to list |
Status: 200, Returns the stored Execution Hook API resource in the JSON response body. Also populates matchingContainers and matchingImages based on the current matchingCriteria and the defined app.
| Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
id |
string |
True |
name |
string |
True |
JSON string containing a user-specified name for the resource. Defined values are:
hookType |
string |
True |
JSON string defining the hook type. Defined values are:
matchingCriteria |
array[matchingCriteria] |
True |
JSON array of JSON objects describing the match criteria for the execution hook. When multiple matchingCriteria are specified a logical AND is applied to criteria. Defined values are:
matchingContainers |
array[matchingContainers] |
False |
JSON array of JSON objects of each container that matches the configured matching criteria within the defined app. |
matchingImages |
array[string] |
False |
JSON array of JSON strings for the matching container images. Defined values are:
action |
string |
True |
JSON string indicating which action the execution hook will run assuming the match criteria are met. Defined values are:
stage |
string |
True |
JSON string indicating the stage during the action that the hook will be executed. Defined values are:
hookSourceID |
string |
True |
JSON string containing the hook source ID that is run through this execution hook. Defined values are:
arguments |
array[string] |
False |
JSON array of JSON strings for the arguments to the source. Defined values are:
appID |
string |
False |
JSON string containing the associated ID of the application that this hook is linked to. In essence, other matching criteria, if set. Defined values are:
enabled |
string |
True |
JSON string that indicates if the execution hook is enabled. Defined values are:
description |
string |
False |
JSON string containing a user-specified description for the hook source. Defined values are:
metadata |
True |
"type": "application/astra-executionHook",
"version": "1.2",
"id": "946e60cb-980b-5374-9e6e-9fe1f6780352",
"name": "Payroll",
"hookType": "custom",
"matchingCriteria": [
"type": "podLabel",
"value": "^env=production$"
"type": "containerName",
"value": "^payroll-master"
"matchingImages": [
"docker.io/bitnami/payroll:3.7.8",
"docker.io/bitnami/payroll:4.1.2"
"matchingContainers": [
"namespaceName": "payroll-east",
"podName": "payroll-release3-7",
"podLabels": [
"name": "env",
"value": "production"
"name": "app.kubernetes.io/managed-by",
"value": "Helm"
"containerName": "payroll-master-0",
"containerImage": "docker.io/bitnami/payroll:3.7.8"
"podLabels": [
"name": "env",
"value": "Helm"
"containerName": "payroll-master-1",
"action": "snapshot",
"stage": "pre",
"hookSourceID": "50e89023-ba84-435d-bb47-1833f4c250ff",
"arguments": [
"freeze"
"appID": "7be5ae7c-151d-4230-ac39-ac1d0b33c2a9",
"enabled": "true",
"description": "Payroll production hook",
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
matchingCriteria
type |
string |
True |
JSON string identifying the match criteria type. |
value |
string |
True |
JSON string containing a regex to match for the given match type. Regex syntax: https://github.com/google/re2/wiki/Syntax |
type_k8s_label
name |
string |
True |
value |
string |
True |
matchingContainers
podName |
string |
False |
JSON string of matching container's pod name. |
podLabels |
array[type_k8s_label] |
False |
JSON array of label objects of matching container's pod's labels. |
containerImage |
string |
False |
JSON string of matching container's image. |
containerName |
string |
False |
JSON string of matching container's name. |
namespaceName |
string |
False |
JSON string of matching container's pod's namespace name. |
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
