List all features
Retrieves all features available in Astra API, providing a comprehensive list of resources in the collection. Use this to view specific fields for each feature according to your request criteria.
HTTP method and endpoint
GET /accounts/{account_id}/core/v1/features
Usage notes
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
account_id |
string |
path |
True |
include |
string |
query |
False |
Indicates which fields should be returned when listing a collection. URL examples: "include=id", "include=id,name" OpenAPI examples: "id" |
limit |
string |
query |
False |
Indicates the maximum number of resources to return when listing a collection. URL examples: "limit=2" OpenAPI examples: "2" |
filter |
string |
query |
False |
Indicates which fields should be matched in order to return a resource when listing a collection. Supported operators are:
URL example: "filter=field%20eq%20%27value%27" OpenAPI examples: "field eq 'value'" |
count |
string |
query |
False |
Indicates if the total number of resources should be returned in the metadata object. URL examples: "count=true" OpenAPI examples: "true" |
orderBy |
string |
query |
False |
Indicates the sort order of resource when listing a collection. URL examples: "orderBy=name", "orderBy=name%20desc" OpenAPI examples: "name desc" |
skip |
string |
query |
False |
Indicates the number of resources to skip over when listing a collection. URL examples: "skip=1" OpenAPI examples: "1" |
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
| Name | Type | Required | Description |
items |
array[Any of: feature_1.1_get_response_body, array[]] |
True |
metadata |
True |
"type": "application/astra-features",
"version": "1.1",
"items": [
"type": "application/astra-feature",
"version": "1.0",
"id": "c1d4d2f7-9b30-45a2-9657-8b24f17a4fd1",
"name": "astra.account.rbac",
"isEnabled": "true",
"metadata": {
"labels": [],
"creationTimestamp": "2021-02-19T22:10:22.448274Z",
"modificationTimestamp": "2021-02-19T22:10:22.448274Z",
"createdBy": "c9550bbb-e70b-4578-8504-07397f875bcb"
"version": "1.0",
"id": "85c693cd-2f89-4944-982a-e885301162bd",
"name": "astra.account.smtp",
"isEnabled": "false",
"metadata": {
"labels": [],
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 503, Service unavailable
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"type": "https://astra.netapp.io/problems/41",
"title": "Service not ready",
"detail": "Currently, the service can't respond to this request.",
"status": "503"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata
Conforms to the Astra Metadata Schema
labels |
array[type_astra_label] |
True |
creationTimestamp |
string |
True |
modificationTimestamp |
string |
True |
createdBy |
string |
True |
modifiedBy |
string |
False |
type |
string |
True |
version |
string |
True |
id |
string |
True |
name |
string |
True |
JSON string containing a name for the feature, in hierarchal dot notation. Defined values are:
isEnabled |
string |
True |
JSON string containing a value indicating whether the feature flag is turned on or off. Defined values are:
metadata |
True |
type_astra_metadata_list
continue |
string |
False |
count |
number |
False |
labels |
False |
creationTimestamp |
string |
False |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
