Retrieve a group
Retrieves a group, providing the stored group resource details for review or integration purposes.
HTTP method and endpoint
GET /accounts/{account_id}/core/v1/groups/{group_id}
Usage notes
Returns the stored Group API resource in the JSON response body.
account_id |
string |
path |
True |
group_id |
string |
path |
True |
ID of the group collection to list |
Status: 200, Returns the stored Group API resource in the JSON response body.
| Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
id |
string |
True |
name |
string |
True |
The name of the group resource. If not specified on create, the value will be set to
authProvider |
string |
True |
The authentication provider for the group resource. Defined values are:
authID |
string |
True |
The Distinguished Name (DN) for an LDAP group. Defined values are:
metadata |
True |
"type": "application/astra-group",
"version": "1.0",
"id": "d8560bb2-7c87-5331-a78d-4e870b22e9a9",
"name": "engineering-group",
"authProvider": "ldap",
"authID": "CN=Engineering,CN=groups,DC=example,DC=com",
"metadata": {
"labels": [],
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"type": "https://astra.netapp.io/problems/12",
"title": "Invalid headers",
"detail": "The request headers are invalid.",
"status": "400"
Status: 500, Internal server error
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"type": "https://astra.netapp.io/problems/34",
"title": "Internal server error",
"detail": "The server was unable to process this request.",
"status": "500"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"type": "https://astra.netapp.io/problems/1",
"title": "Resource not found",
"detail": "The resource specified in the request URI wasn't found.",
"status": "404"
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
