List all hook sources
Retrieves all hook sources in the collection. Use this to view the available fields for each resource as specified in your request.
HTTP method and endpoint
GET /accounts/{account_id}/core/v1/hookSources
Usage notes
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
account_id |
string |
path |
True |
include |
string |
query |
False |
Indicates which fields should be returned when listing a collection. URL examples: "include=id", "include=id,name" OpenAPI examples: "id" |
limit |
string |
query |
False |
Indicates the maximum number of resources to return when listing a collection. URL examples: "limit=2" OpenAPI examples: "2" |
filter |
string |
query |
False |
Indicates which fields should be matched in order to return a resource when listing a collection. Supported operators are:
URL example: "filter=field%20eq%20%27value%27" OpenAPI examples: "field eq 'value'" |
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
| Name | Type | Required | Description |
items |
array[Any of: hookSource_1.0_get_response_body, array[]] |
True |
metadata |
True |
"type": "application/astra-hookSources",
"version": "1.0",
"items": [
"type": "application/astra-hookSource",
"version": "1.0",
"id": "2d6154dd-6863-4a26-8017-6be092b8b0bd",
"name": "Payroll script",
"private": "false",
"preloaded": "false",
"sourceType": "script",
"source": "ZWNobyAiVkhKaGJuTWdVbWxuYUhSeklRPT0iIHwgYmFzZTY0IC1k",
"sourceMD5Checksum": "b1a4b8b0144c3f6be553b626130ca145",
"description": "Pre and post hook script for payroll",
"metadata": {
"labels": [],
"creationTimestamp": "2020-08-06T12:24:52.256624Z",
"modificationTimestamp": "2020-08-06T12:24:52.256624Z",
"createdBy": "64182074-ddb6-42eb-b7f4-b6a02cf9ba7c"
"version": "1.0",
"id": "b71c6793-aa9b-4654-92ef-60663a0aedac",
"private": "true",
"sourceMD5Checksum": "6469094cb279f6d91358bc5062d15baf",
"metadata": {
"labels": [],
"creationTimestamp": "2020-08-08T12:24:52.256624Z",
"modificationTimestamp": "2020-08-08T12:24:52.256624Z",
"version": "1.0",
"id": "682fe9d2-52d2-4c30-bcec-ecefddde359c",
"name": "NetApp preloaded ",
"private": "true",
"sourceMD5Checksum": "7864495443c1087104520a320a2225c9",
"description": "NetApp Postgres preloaded snapshot pre and post",
"metadata": {
"labels": [],
"creationTimestamp": "2020-07-12T12:24:52.256624Z",
"modificationTimestamp": "2020-07-12T12:24:52.256624Z",
"createdBy": "4428cfd4-27fd-4248-9f49-bd3a02043ab8"
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
type |
string |
True |
version |
string |
True |
id |
string |
True |
name |
string |
True |
JSON string containing a user-specified name for the resource. Defined values are:
private |
string |
True |
JSON string indicating whether the source field will be exposed in APIs or be intentionally left blank. Defined values are:
preloaded |
string |
True |
JSON string that indicates whether the source was preloaded. Defined values are:
sourceType |
string |
True |
JSON string defining the hook source type. Defined values are:
source |
string |
False |
JSON string containing the script to be run in base64 format. Defined values are:
sourceMD5Checksum |
string |
True |
JSON string containing the MD5 checksum computed for the value of the "source" key. Defined values are:
description |
string |
False |
JSON string containing a user-specified description of the hook source. Defined values are:
metadata |
True |
type_astra_metadata_list
continue |
string |
False |
count |
number |
False |
labels |
False |
creationTimestamp |
string |
False |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
