Retrieve an LDAP user
Retrieves an LDAP user, providing the stored resource configuration for user management and authentication tasks.
HTTP method and endpoint
GET /accounts/{account_id}/core/v1/ldapUsers/{ldapUser_id}
Usage notes
Returns a JSON object representing the stored LDAP resource.
account_id |
string |
path |
True |
ldapUser_id |
string |
path |
True |
ID of the ldapUser collection to list |
Status: 200, Returns a JSON object representing the stored LDAP resource.
| Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
id |
string |
True |
string |
False |
JSON string representing the email of the LDAP user. Defined values are:
firstName |
string |
False |
JSON string representing the first name of the LDAP user. Defined values are:
lastName |
string |
False |
JSON string representing the last name of the LDAP user. Defined values are:
cn |
string |
False |
JSON string representing the LDAP group name. Defined values are:
dn |
string |
False |
JSON string representing the distinguished name of the LDAP group. Defined values are:
metadata |
True |
"type": "application/astra-ldapUser",
"version": "1.0",
"id": "2add73ff-89dc-5ff1-be85-39d97549556d",
"email": "johndoe@example.com",
"firstName": "John",
"lastName": "Doe",
"cn": "John Doe",
"dn": "cn=John Doe,ou=people,dc=example,dc=com",
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata
Conforms to the Astra Metadata Schema
labels |
array[type_astra_label] |
True |
creationTimestamp |
string |
True |
modificationTimestamp |
string |
True |
createdBy |
string |
True |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
