Astra Automation
List all packages
Retrieves all package resources in the collection, providing detailed information for each matching resource. Use this to view specific fields of interest in the returned data.
HTTP method and endpoint
GET /accounts/{account_id}/core/v1/packages
Usage notes
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
account_id
string
path
True
  • example: {{.Account}}
filter
string
query
False
Indicates which fields should be matched in order to return a resource when listing a collection.
Supported operators are:
  • eq - Equality
  • lt/gt - Less than/Greater than
  • lte/gte - Less than or equals to/Greater than or equals to
URL example: "filter=field%20eq%20%27value%27"
OpenAPI examples: "field eq 'value'"
orderBy
string
query
False
Indicates the sort order of resource when listing a collection.
URL examples: "orderBy=name", "orderBy=name%20desc"
OpenAPI examples: "name desc"
include
string
query
False
Indicates which fields should be returned when listing a collection.
URL examples: "include=id", "include=id,name"
OpenAPI examples: "id"
  • example: id,packageName,packageVersion,softwareType
limit
string
query
False
Indicates the maximum number of resources to return when listing a collection.
URL examples: "limit=2"
OpenAPI examples: "2"
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
items
array[Any of: package_1.0_get_response_body, array[]]
True
metadata
type_astra_metadata_list
True
  "type": "application/astra-packages",
  "version": "1.0",
  "items": [
      "e280ff62-be35-4f31-a31b-a210a1ad1b33",
      "acc",
      "22.01.0",
      "install"
      "e8507dad-d33f-44b3-9c15-ec55ba6f6473",
      "acc",
      "22.01.1",
      "patch"
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "status": "404"
type_astra_stateTransition
from
string
True
to
array[string]
True
type_astra_stateDetail
type
string
True
title
string
True
detail
string
True
dependsOnImages
imagePath
string
True
JSON string containing the path to this Docker image. It must not contain the name of the registry, only the absolute path from root to image. Example: /globalcicd/acc Defined values are:
  • Minimum length: 1
  • Maximum length: 1023
imageName
string
True
JSON string containing the Docker image name. Defined values are:
  • Minimum length: 1
  • Maximum length: 63
imageTag
string
True
JSON string representing the tag/version of this image. Defined values are:
  • Minimum length: 1
  • Maximum length: 31
images
imageName
string
True
  • Minimum length: 1
imagePath
string
True
  • Minimum length: 1
imageTag
string
True
  • Minimum length: 1
imageDigest
string
True
JSON string representing the digest of this image. Defined values are:
  • Defined regex is: "^(sha256:)[0-9a-f]{64}$"
dependsOnImages
array[dependsOnImages]
False
JSON array of JSON objects describing the images required to install or upgrade the current image.
dependsOnComponents
componentName
string
True
JSON string describing the name of the component. Defined values are:
  • "acc"
  • "acs"
  • "trident"
  • "kubernetes"
versions
array[string]
True
JSON array of JSON strings defining the component version required to install the current image.
artifacts
artifactName
string
True
JSON string containing the file name. Defined values are:
  • Minimum length: 1
artifactIdentifier
string
True
JSON string containing an identifier for this file. Between versions of the same package type, the file name might change but the identifier usually stays the same. Defined values are:
  • Minimum length: 1
  • Maximum length: 511
artifactPath
string
True
JSON string containing the path to this artifact from the root of a known Astra Control Center Data Store/location. Example: /vmware/1.0/ Defined values are:
  • Minimum length: 1
artifactVersion
string
False
JSON string containing the version of that artifact, if provided. Defined values are:
  • Conforms to the SemVer Schema
  • Minimum length: 1
dependsOnComponents
array[dependsOnComponents]
False
JSON array of JSON objects describing the installed components required to install/upgrade the current image.
files
fileName
string
True
  • Minimum length: 1
fileIdentifier
string
True
JSON string containing an identifier of this file. Between versions of the same package type, the file name might change but the identifier usually stays the same. Defined values are:
  • Minimum length: 1
fileMediaType
string
True
JSON string containing the file media-type. Defined values are any media type defined by IANA. In addition, application/x-yaml or application/x-yaml for yaml files is supported.
  • Minimum length: 1
  • Maximum length: 211
fileContents
string
True
JSON string containing the file content. Defined values are:
  • Conforms to the Base64 Schema FIXME - How do we specify that this is compressed? What algorithm ,etc?
upgradableVersions
JSON object containing the minimum and maximum versions that can be upgraded to the package version.
minVersion
string
False
JSON string describing the minimum version that can be upgraded to the package version. Defined values are:
maxVersion
string
False
JSON string describing the maximum version that can be upgraded to the package version. Defined values are:
dependencies
componentName
string
True
  • "acc"
  • "acs"
  • "trident"
  • "kubernetes"
componentMinVersion
string
False
JSON string describing the minimum version required of that component. Defined values are:
componentMaxVersion
string
False
JSON string describing the maximum version required of that component. Defined values are:
type_astra_label
name
string
True
value
string
True
type_astra_metadata
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels.
labels
array[type_astra_label]
True
creationTimestamp
string
True
string
True
createdBy
string
True
modifiedBy
string
False
type
string
True
  • "application/astra-package"
version
string
True
  • "1.0"
id
string
True
packageName
string
True
JSON string containing the package name. Defined values are:
  • Minimum length: 1
  • Maximum length: 31 Example values are:
  • "acc"
  • "acs"
  • "trident"
packageVersion
string
True
JSON string containing the SemVer of the package. Defined values are:
packageType
string
True
JSON string containing the package type, indicating whether this is a full installation package or a patch. Defined values are:
  • "install"
  • "patch"
bundleName
array[string]
False
JSON array of JSON strings containing the name of the bundle that the package is contained in.
severityLevel
string
True
JSON string describing the severity level of this patch or installation. Defined values are:
  • "recommended" - Installation is recommended - Default value
  • "critical" - Installation is strongly recommended to address critical bug fixes and/or security patches
packageState
string
True
JSON string containing a value indicating the operational state of the package. After verification of the package and after import, the state will indicate "complete". Otherwise, the state will indicate "incomplete". Defined values are:
  • "verifying" - The package is in the process of being validated
  • "corrupt" - The package is corrupt
  • "incomplete" - The package is missing elements
  • "available" - All elements associated with the package are available and the package is ready for use
packageStateTransitions
array[type_astra_stateTransition]
True
JSON array of JSON objects, each representing the set of permitted state transitions from a given defined state. Each JSON object contains the fields "from" and "to", where the "from" value is the name of a state and the "to" value is an array of permitted destination states. Defined values are:
  • Conforms to the State Transition Schema
packageStateDetails
array[type_astra_stateDetail]
True
JSON array of JSON objects that lists additional details about the current "state". If no details are available, this array will be empty.
  • Minimum Items: 0
images
array[images]
False
JSON array of JSON objects, each containing a Docker image that is part of the package.
artifacts
array[artifacts]
False
JSON array of JSON objects describing the additional artifacts (binaries and others) associated with this package.
files
array[files]
False
JSON array of JSON objects, each representing a non-image artifact associated with this package.
upgradableVersions
upgradableVersions
False
dependencies
array[dependencies]
False
JSON array of JSON objects describing what minimum version of a given dependency is required for this package to be installed
metadata
type_astra_metadata
True
continue
string
False
count
number
False
labels
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
