List the role bindings for a user
Retrieves role bindings for a user, providing you with the necessary information to manage user permissions effectively.
HTTP method and endpoint
GET /accounts/{account_id}/core/v1/users/{user_id}/roleBindings
Usage notes
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
account_id |
string |
path |
True |
user_id |
string |
path |
True |
ID of the containing user resource |
include |
string |
query |
False |
Indicates which fields should be returned when listing a collection. URL examples: "include=id", "include=id,name" OpenAPI examples: "id"
limit |
string |
query |
False |
Indicates the maximum number of resources to return when listing a collection. URL examples: "limit=2" OpenAPI examples: "2" |
filter |
string |
query |
False |
Indicates which fields should be matched in order to return a resource when listing a collection. Supported operators are:
URL example: "filter=field%20eq%20%27value%27" OpenAPI examples: "field eq 'value'" |
orderBy |
string |
query |
False |
Indicates the sort order of resource when listing a collection. URL examples: "orderBy=name", "orderBy=name%20desc" OpenAPI examples: "name desc" |
skip |
string |
query |
False |
Indicates the number of resources to skip over when listing a collection. URL examples: "skip=1" OpenAPI examples: "1" |
count |
string |
query |
False |
Indicates if the total number of resources should be returned in the metadata object. URL examples: "count=true" OpenAPI examples: "true" |
continue |
query |
False |
Indicates the token to resume listing from. URL examples: "continue= OpenAPI examples: " |
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
| Name | Type | Required | Description |
items |
array[Any of: roleBinding_1.1_get_response_body, array[]] |
True |
metadata |
True |
"type": "application/astra-roleBindings",
"version": "1.1",
"items": [
"9fd87309-067f-48c9-a331-527796c14cf3",
"4c27d25a-9edb-4e85-9438-48dc8e917231",
"viewer"
"dc40a13f-e9b3-4cf5-900f-58de32174390",
"owner"
"c38abd8d-7dae-4659-8382-2e74a58738ba",
"owner"
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
type |
string |
True |
version |
string |
True |
id |
string |
True |
principalType |
string |
True |
JSON string representing the type of the principal this binding is associated with. Defined values are:
userID |
string |
True |
JSON string containing a user resource ID. Defined values are:
groupID |
string |
True |
JSON string containing a group resource ID. Defined values are:
accountID |
string |
True |
JSON string containing the ID of an account resource. For create, this must match the account ID in the request URI. Defined values are:
role |
string |
True |
JSON string containing one of the four defined roles. Defined values are:
roleConstraints |
array[string] |
False |
JSON array of JSON strings specifying the scope of the role assignment. Defined values are:
metadata |
True |
type_astra_metadata_list
continue |
string |
False |
count |
number |
False |
labels |
False |
creationTimestamp |
string |
False |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
