Astra Automation
List all users
Retrieves a list of all users in the system, providing access to user information and configurations. Use this to review or manage user accounts efficiently.
HTTP method and endpoint
GET /accounts/{account_id}/core/v1/users
Usage notes
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
account_id
string
path
True
  • example: {{.Account}}
include
string
query
False
Indicates which fields should be returned when listing a collection.
URL examples: "include=id", "include=id,name"
OpenAPI examples: "id"
  • example: id,email
limit
string
query
False
Indicates the maximum number of resources to return when listing a collection.
URL examples: "limit=2"
OpenAPI examples: "2"
filter
string
query
False
Indicates which fields should be matched in order to return a resource when listing a collection.
Supported operators are:
  • eq - Equality
  • lt/gt - Less than/Greater than
  • lte/gte - Less than or equals to/Greater than or equals to
URL example: "filter=field%20eq%20%27value%27"
OpenAPI examples: "field eq 'value'"
orderBy
string
query
False
Indicates the sort order of resource when listing a collection.
URL examples: "orderBy=name", "orderBy=name%20desc"
OpenAPI examples: "name desc"
skip
string
query
False
Indicates the number of resources to skip over when listing a collection.
URL examples: "skip=1"
OpenAPI examples: "1"
count
string
query
False
Indicates if the total number of resources should be returned in the metadata object.
URL examples: "count=true"
OpenAPI examples: "true"
continue
query
False
Indicates the token to resume listing from.
URL examples: "continue="
OpenAPI examples: ""</continue>
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
items
array[Any of: user_1.2_get_response_body, array[]]
True
metadata
type_astra_metadata_list
True
  "type": "application/astra-users",
  "version": "1.2",
  "items": [
      "11c0cfa1-4f27-4ef7-a21c-cb452fc5c9aa",
      "jdoe@example.com"
      "e324ec3a-706d-4f57-a95d-1d88c03e7b73",
      "ssmith@example.com"
      "3070c84d-129b-4017-82a8-2c26a42dd77e",
      "wjohns@example.com"
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "status": "404"
postalAddress
JSON object containing a collection of fields that specifies an address. If this key does not exist, it indicates that an address has not been provided. If this key exists, all six of the contained fields will be present. If nothing was provided by the user, the string will be empty.
addressCountry
string
True
JSON string containing the country name or country code associated with the postal address, as specified in ISO 3166 Alpha-2. Defined values are:
  • Minimum length: 2
  • Maximum length: 2
addressLocality
string
True
JSON string containing the locality (for example, city) associated with the postal address. Defined values are:
  • Minimum length: 1
  • Maximum length: 63
addressRegion
string
True
JSON string containing the region (for example, state) associated with the postal address. Defined values are:
  • Minimum length: 1
postalCode
string
True
JSON string containing the postal code associated with the postal address. Defined values are:
  • Minimum length: 1
streetAddress1
string
True
JSON string containing the street address associated with the postal address. Defined values are:
  • Minimum length: 1
streetAddress2
string
False
JSON string containing optional ancillary street address information, post office box, and so on. Defined values are:
  • Minimum length: 1
type_astra_label
name
string
True
value
string
True
type_astra_metadata_update
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels
array[type_astra_label]
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
type
string
True
  • "application/astra-user"
version
string
True
  • "1.0"
  • "1.1"
  • "1.2"
id
string
True
state
string
True
JSON string containing a value indicating the operational state of the user. Defined values are:
  • "pending" - The user account is in the process of being created. The user can only read and modify the user resource (default value).
  • This state is not valid for a user with "authProvider" as "local"
  • "active" - The user account is operational (The user can log in if the account setting "isEnabled" is "true").
  • This is the default value for a user with "authProvider" as "local"
  • "suspended" - The user account is suspended (The user cannot log in regardless of account "isEnabled" setting).
isEnabled
string
True
JSON string indicating if the user is allowed to log in. Defined values are:
  • "true" - The user is allowed to log in; default value on create.
  • "false" - The user is not allowed to log in.
authID
string
False
JSON string containing the identifier associated with an external identity provider. The contents of this string depend on the specified authProvider. For a user with "authProvider" as "local", "authID" is set to the value of "email". For a user with "authProvider" as "ldap", "authID" is set to its Distinguished Name (DN) from the LDAP server.
authProvider
string
False
JSON string indicating the context of the idAuth identifier. Defined values are:
  • "cloud-central" - User authentication comes from the NetApp Cloud Central service
  • "local" - User authentication comes from the local user/password store
  • "ldap" - User authentication comes from an external LDAP server In Astra Control Center, all users are required to have a value of "local", or "ldap". If a value is not specified, a default value of "local" is chosen. In Astra Control Service, "authProvider" as "local", or "ldap" is not supported. If a value is not specified, it will default to "cloud-central".
firstName
string
True
JSON string containing a user-specified long form first name. Defined values are:
  • Minimum length: 0
  • This string is internally validated to prevent XSS, Unicode, directory traversal, and SQL-injection attacks
lastName
string
True
JSON string containing a user-specified long-form last name. Defined values are:
  • Minimum length: 0
companyName
string
False
JSON string containing the company name associated with the user. If this key does not exist, it indicates that a company name has not been provided. Defined values are:
  • Minimum length: 1
email
string
True
JSON strings containing a user-specified email address.
phone
string
False
JSON string containing the phone number of the user. If this key does not exist, it indicates that a phone number has not been provided.
postalAddress
postalAddress
False
sendWelcomeEmail
string
True
JSON string indicating whether a welcome email will be sent after validation. If not specified on create, the value will be set to "true" for ACS and "false" for Astra Control Center. Defined values are:
  • "true" - A welcome email will be sent; default value on create
  • "false" - A welcome email will not be sent For a user with "authProvider" as "local" or "ldap", this value is ignored and is set to "false".
enableTimestamp
string
False
JSON string containing an ISO-8601 formatted timestamp indicating when the user was last enabled. Defined values are:
  • Conforms to the ISO-8601 Date Time Schema
lastActTimestamp
string
False
JSON string containing an ISO-8601 formatted timestamp indicating when the identity API was last invoked on behalf of this user. (Note: This is expensive.) Defined values are:
metadata
True
continue
string
False
count
number
False
labels
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
