Astra Automation
List the storage classes for a cloud
Retrieves a list of storage classes for a cloud, providing details on available configurations for cloud storage resources.
HTTP method and endpoint
GET /accounts/{account_id}/topology/v1/clouds/{cloud_id}/clusters/{cluster_id}/storageClasses
Usage notes
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
account_id
string
path
True
  • example: {{.Account}}
cloud_id
string
path
True
ID of the containing cloud resource
cluster_id
string
path
True
ID of the containing cluster resource
include
string
query
False
Indicates which fields should be returned when listing a collection.
URL examples: "include=id", "include=id,name"
OpenAPI examples: "id"
  • example: id,name
limit
string
query
False
Indicates the maximum number of resources to return when listing a collection.
URL examples: "limit=2"
OpenAPI examples: "2"
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
items
array[Any of: storageClass_1.1_get_response_body, array[]]
True
metadata
type_astra_metadata_list
True
  "type": "application/astra-storageClasses",
  "version": "1.1",
  "items": [
      "e280ff62-be35-4f31-a31b-a210a1ad1b33",
      "my-storage-class"
      "e8507dad-d33f-44b3-9c15-ec55ba6f6473",
      "standard"
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "status": "404"
type_astra_label
name
string
True
value
string
True
type_astra_metadata
  • Conforms to the Astra Metadata Schema
labels
array[type_astra_label]
True
creationTimestamp
string
True
string
True
createdBy
string
True
modifiedBy
string
False
type
string
True
  • "application/astra-storageClass"
version
string
True
  • "1.0"
  • "1.1"
id
string
True
name
string
True
JSON string containing a value indicating the name of the storage class. Defined values are:
  • Minimum length: 1
  • Maximum length: 255
provisioner
string
True
JSON string containing a value indicating the provisioner associated with the storage class. Defined values are:
  • Minimum length: 1
available
string
True
JSON string indicating whether the storage class is available for the cluster or is eligible to be added to the cluster when under management. Defined values are:
  • "available" - The storage class is available for use
  • "eligible" - The storage class is eligible to be used by the cluster when it is under management
  • "ineligible" - The storage class is ineligible to be used by the cluster when it is under management
allowVolumeExpansion
string
True
JSON string indicating whether the storage class allows volume expansion. Defined values are:
  • "true" - The storage class allows volume expansion
  • "false" - The storage class does not allow volume expansion
  • "unavailable" - It is unknown whether the storage class allows volume expansion
reclaimPolicy
string
True
JSON string containing a cloud-specific value indicating the retention policy of the storage class. Defined values are:
  • Minimum length: 1
volumeBindingMode
string
True
JSON string containing a cloud-specific value indicating the binding mode for the storage class. Defined values are:
  • Minimum length: 1
isDefault
string
False
JSON string indicating whether the storage class contains the default annotation. Defined values are:
  • "true" - The storage class contains the default annotation
maxSnapshotCount
number
False
JSON number indicating how many snapshots are supported. This information is attached to storage classes provided by NetApp.
maxBackupCount
number
False
JSON number indicating how many backups are supported. This information is attached to storage classes provided by NetApp.
price
string
False
JSON string indicating the currency units per unit of time for the storage class. This information is attached to storage classes provided by NetApp. Defined values are:
  • Minimum length: 1
  • Maximum length: 63
currency
string
False
JSON string indicating the ISO 4217 three-letter code for the currency that the price is measured in. This information is attached to storage classes provided by NetApp. Defined values are:
  • Minimum length: 1
performance
number
False
JSON number indicating the performance service-level objective (SLO) in MBps. This information is attached to storage classes provided by NetApp.
resilience
string
False
JSON string indicating the resilience configuration for the storage. This information is attached to storage classes provided by NetApp. Defined values are:
  • "regional" - The volume will become unavailable if a given region becomes unavailable
  • "multisite" - The volume will continue to be available if a given region becomes unavailable
metadata
type_astra_metadata
True
continue
string
False
count
number
False
labels
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
