Retrieve a cluster node for a cluster
Retrieves a cluster node for a cluster, offering details about the node's configuration and status within the specified cluster.
HTTP method and endpoint
GET /accounts/{account_id}/topology/v1/clusters/{cluster_id}/clusterNodes/{clusterNode_id}
Usage notes
Returns the stored Cluster Node API resource in the JSON response body.
account_id |
string |
path |
True |
cluster_id |
string |
path |
True |
ID of the containing cluster resource |
clusterNode_id |
string |
path |
True |
ID of the clusterNode collection to list |
Status: 200, Returns the stored Cluster Node API resource in the JSON response body.
| Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
id |
string |
True |
name |
string |
True |
JSON string containing a value that indicates the Kubernetes name for the node. Defined values are:
role |
string |
True |
JSON string containing a value that indicates the Kubernetes role for the node. Defined values are:
labels |
array[labels] |
True |
JSON array of JSON objects, each containing Kubernetes labels associated with the node. If no details are available, this array will be empty.
creationTime |
string |
True |
JSON string containing an ISO 8601 timestamp that indicates when the node was created. Defined values are:
externalIP |
string |
True |
JSON string containing a value that indicates the internal IP address for the node. Defined values are:
internalIP |
string |
True |
JSON string containing a value that indicates the external IP address for the node. Defined values are:
zone |
string |
True |
JSON string containing a value that indicates the Kubernetes zone for the node. Defined values are:
region |
string |
True |
JSON string containing a value that indicates the Kubernetes region for the node. Defined values are:
instanceType |
string |
True |
JSON string containing a value that indicates the Kubernetes instance type for the node. Defined values are:
kernelVersion |
string |
True |
JSON string containing a value that indicates the kernel version used by the node. Defined values are:
osImage |
string |
True |
JSON string containing a value that indicates the operating system image used by the node. Defined values are:
numCpus |
string |
True |
JSON string containing a value that indicates the number of CPUs assigned to the node. Defined values are:
memory |
string |
True |
JSON string containing a value that indicates the amount of memory assigned to the node. Defined values are:
state |
string |
True |
JSON string containing a value indicating the operational state of the node. Defined values are:
metadata |
True |
"type": "application/astra-clusterNode",
"version": "1.0",
"id": "5df0e09f-2c30-5b8a-b6b6-4fb4063525e4",
"name": "test-0",
"role": "node-role.kubernetes.io/worker",
"labels": [],
"creationTime": "2020-09-06T04:35:23.593845Z",
"externalIP": "192.168.12.44",
"internalIP": "10.0.1.1",
"zone": "us-west1-c",
"region": "us-east1",
"instanceType": "e2-medium",
"kernelVersion": "4.18.0-147.0.3.el8_1.x86_64",
"osImage": "Red Hat Enterprise Linux CoreOS 42.81.20191203.0",
"numCpus": "2",
"memory": "67108864Ki",
"state": "running",
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
labels
name |
string |
True |
JSON string containing the label name Defined values are:
value |
string |
True |
JSON string containing the label value Defined values are:
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata
Conforms to the Astra Metadata Schema
labels |
array[type_astra_label] |
True |
creationTimestamp |
string |
True |
modificationTimestamp |
string |
True |
createdBy |
string |
True |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
