Astra Automation
Astra API (ACS) hook source endpoints
Manage hook sources separately from execution hooks so that several hooks can share one source. Updating a shared source applies the change everywhere it is used.
The Hook Source API enables simple management of hook sources separate from the management of the execution hook resources. For example, a single hook source can be referenced by multiple execution hooks to avoid duplicate hook sources and allow a single API call to update one hook source, even if it is used by multiple execution hook resources.
