Create a new ASUP resource
Creates an ASUP resource to specify the desired values for automated support uploads.
HTTP method and endpoint
POST /accounts/{account_id}/core/v1/asups
Usage notes
Indicates the desired values for the ASUP API resource to be created.
account_id |
string |
path |
True |
Request Body
| Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
upload |
string |
True |
JSON string containing a value indicating whether to upload the AutoSupport bundle after successful creation. Defined values are:
dataWindowStart |
string |
False |
JSON string containing a timestamp indicating the start time of the AutoSupport bundle data collection window. Defaults to 24 hours before the "dataWindowEnd" key value. Must occur before the "dataWindowEnd" key value. Maximum is 7 days before the current time of the request. Defined values are:
dataWindowEnd |
string |
False |
JSON string containing a timestamp indicating the end time of the AutoSupport bundle data collection window. Defaults to the current time of the request. Defined values are:
metadata |
False |
Example request
"type": "application/astra-asup",
"version": "1.0",
"upload": "true"
Status: 201, Returns the newly created asup resource in the JSON response body.
type |
string |
True |
version |
string |
True |
id |
string |
True |
creationState |
string |
True |
JSON string containing a value indicating the creation state of the AutoSupport bundle. For "completed" and "partial" states, the bundle can be downloaded by performing a GET of the resource URI with an Accept header containing "/" or "application/gzip". Defined values are:
creationStateDetails |
array[type_astra_stateDetail] |
True |
JSON array of JSON objects that lists additional details about why "creationState" transitioned into "partial" or "failed". If no details are available, this array will be empty.
upload |
string |
True |
uploadState |
string |
False |
JSON string containing a value that indicates the state of the AutoSupport bundle upload if it was requested. Defined values are:
uploadStateDetails |
False |
JSON array of JSON objects that lists additional details about why "uploadState" transitioned into "failed". If no details are available, this array will be empty.
triggerType |
string |
True |
JSON string containing a value that indicates what triggered the creation of the ASUP resource. Defined values are:
dataWindowStart |
string |
True |
dataWindowEnd |
string |
True |
metadata |
True |
"version": "1.0",
"id": "9950003f-a1c7-5ca7-8930-06eec25f60aa",
"creationState": "running",
"creationStateDetails": [],
"upload": "true",
"uploadState": "pending",
"uploadStateDetails": [],
"triggerType": "manual",
"dataWindowStart": "2020-08-05T12:24:00.000000Z",
"dataWindowEnd": "2020-08-06T12:24:52.000000Z",
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
array[invalidFields] |
False |
List of invalid request body fields |
"status": "400"
Status: 409, Conflict
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
False |
"status": "409"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels.
labels |
array[type_astra_label] |
True |
creationTimestamp |
string |
True |
modificationTimestamp |
string |
True |
createdBy |
string |
True |
modifiedBy |
string |
False |
type |
string |
True |
title |
string |
True |
detail |
string |
True |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
invalidFields
name |
string |
True |
Name of the invalid request body field |
reason |
string |
True |
Reason why the request body field is invalid |
