Create a new certificate
Creates a new certificate for the Certificate API resource. Use this to specify the desired values for secure communications.
HTTP method and endpoint
POST /accounts/{account_id}/core/v1/certificates
Usage notes
Indicates the desired values for the Certificate API resource to be created.
account_id |
string |
path |
True |
Request Body
| Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
certUse |
string |
False |
JSON string indicating the use of the certificate. If not specified, defaults to "rootCA". Defined values are:
cert |
string |
True |
JSON string containing a base64 encoded PKCS-11 formatted certificate (PEM). Defined values are:
isSelfSigned |
string |
False |
JSON string indicating whether the certificate is self-signed. If not provided on create, the value defaults to "false". On update:
trustStateDesired |
string |
False |
JSON string containing a value indicating whether the certificate is trusted. If not specified on create, the default value is "trusted". Defined values are:
metadata |
False |
Example request
"type": "application/astra-certificate",
"version": "1.1",
"certUse": "rootCA",
"cert": "LS0tLS1CRUdJTiBDRVJUSUZJQ0FURS0tLS0tCk1JSUZyVENDQTVXZ0F3MVJHbnFGbUJSSWRyV1kwPQotLS0tLUVORCBDRVJUSUZJQ0FURS0tLS0t"
Status: 201, Returns the newly created certificate resource in the JSON response body.
type |
string |
True |
version |
string |
True |
id |
string |
True |
certUse |
string |
True |
cert |
string |
True |
cn |
string |
True |
JSON string containing a common name extracted from the certificate. Defined values are:
expiryTimestamp |
string |
True |
JSON string containing a timestamp indicating when the certificate expires. Defined values are:
isSelfSigned |
string |
True |
trustState |
string |
True |
JSON string containing one of a set of enumerated values indicating whether the certificate is trusted. Defined values are:
trustStateTransitions |
array[type_astra_stateTransition] |
True |
JSON array of JSON objects, each representing the set of permitted state transitions from a given defined state. Each JSON object contains the fields "from" and "to", where the "from" value is the name of a state, and the "to" value is an array of permitted destination states. |
trustStateDesired |
string |
False |
trustStateDetails |
array[type_astra_stateDetail] |
True |
JSON array of JSON objects that lists additional details about the trust state of the certificate. If no details are available, this array will be empty.
metadata |
True |
"version": "1.1",
"id": "a26cbed4-2183-58ce-aa19-e37ca8b0531a",
"cert": "LS0tLS1CRUdJTiBDRVJUSUZJQ0FURS0tLS0tCk1JSUZyVENDQTVXZ0F3MVJHbnFGbUJSSWRyV1kwPQotLS0tLUVORCBDRVJUSUZJQ0FURS0tLS0t",
"cn": "vcenter.example.com",
"isSelfSigned": "false",
"expiryTimestamp": "2022-03-23T16:48:38.5233461Z",
"trustState": "trusted",
"trustStateTransitions": [
"from": "untrusted",
"to": [
"trusted"
"from": "trusted",
"to": [
"untrusted"
"trustStateDesired": "trusted",
"trustStateDetails": [],
"metadata": {
"labels": [],
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
array[invalidFields] |
False |
List of invalid request body fields |
"type": "https://astra.netapp.io/problems/7",
"title": "Invalid JSON payload",
"detail": "The request body is not valid JSON.",
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 500, Internal server error
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"type": "https://astra.netapp.io/problems/34",
"title": "Internal server error",
"detail": "The server was unable to process this request.",
"status": "500"
Status: 503, Service unavailable
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"type": "https://astra.netapp.io/problems/41",
"title": "Service not ready",
"detail": "Currently, the service can't respond to this request.",
"status": "503"
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "401"
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
from |
string |
True |
to |
array[string] |
True |
type |
string |
True |
title |
string |
True |
detail |
string |
True |
invalidFields
name |
string |
True |
Name of the invalid request body field |
reason |
string |
True |
Reason why the request body field is invalid |
