Create a new hook source
Creates a new hook source, specifying the values for the Hook Source API resource to initiate the creation process. Use this endpoint when you need to establish a hook source for automation or integration tasks.
HTTP method and endpoint
POST /accounts/{account_id}/core/v1/hookSources
Usage notes
Indicates the desired values for the Hook Source API resource to be created.
account_id |
string |
path |
True |
Request Body
| Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
name |
string |
True |
JSON string containing a user-specified name for the resource. Defined values are:
sourceType |
string |
True |
JSON string defining the hook source type. Defined values are:
source |
string |
True |
JSON string containing the script to be run in base64 format. Defined values are:
description |
string |
False |
JSON string containing a user-specified description of the hook source. Defined values are:
metadata |
False |
Example request
"type": "application/astra-hookSource",
"version": "1.0",
"name": "Payroll script",
"sourceType": "script",
"source": "ZWNobyAiVkhKaGJuTWdVbWxuYUhSeklRPT0iIHwgYmFzZTY0IC1k",
"description": "Pre and post hook script for payroll"
Status: 201, Returns the newly created hookSource resource in the JSON response body.
type |
string |
True |
version |
string |
True |
id |
string |
True |
name |
string |
True |
private |
string |
True |
JSON string indicating whether the source field will be exposed in APIs or be intentionally left blank. Defined values are:
preloaded |
string |
True |
JSON string that indicates whether the source was preloaded. Defined values are:
sourceType |
string |
True |
source |
string |
False |
sourceMD5Checksum |
string |
True |
JSON string containing the MD5 checksum computed for the value of the "source" key. Defined values are:
description |
string |
False |
metadata |
True |
"version": "1.0",
"id": "fae6dfbb-ecb8-58ff-a116-6357eb7c956a",
"private": "false",
"preloaded": "false",
"sourceMD5Checksum": "b1a4b8b0144c3f6be553b626130ca145",
"description": "Pre and post hook script for payroll",
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
array[invalidFields] |
False |
List of invalid request body fields |
"status": "400"
Status: 409, Conflict
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
False |
"status": "409"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
invalidFields
name |
string |
True |
Name of the invalid request body field |
reason |
string |
True |
Reason why the request body field is invalid |
