Astra Automation
Create a new AppMirror resource
Creates a new AppMirror resource, specifying the desired values for replication and synchronization of applications across environments.
HTTP method and endpoint
POST /accounts/{account_id}/k8s/v1/appMirrors
Usage notes
Indicates the desired values for the AppMirror API resource to be created.
account_id
string
path
True
  • example: {{.Account}}
Request Body
type
string
True
  • "application/astra-appMirror"
version
string
True
  • "1.0"
sourceAppID
string
True
Identifier of the source application. Only updated when swapping the sourceAppID with the destinationAppID. Defined values are:
  • Conforms to the Astra Identifier Schema
destinationClusterID
string
True
Identifier of the managed cluster to host the destination application. Must be provided on create because it determines what cluster the destination application will be created on. If provided on update, it must match the cluster ID of the destination application, so it can only change when swapping sourceAppID with destinationAppID. Defined values are:
namespaceMapping
array[namespaceMapping]
False
The namespace or namespaces to use when creating the destination application, corresponding to the namespaces of the source application. Each JSON object contains the fields "clusterID" and "namespaces", where the "clusterID" value is the JSON string ID of the source or destination cluster, and the "namespaces" value is a JSON array of JSON strings. There must be exactly one JSON object for each cluster, and the namespaces will be correlated by index. If not provided, the same namespace from the source cluster will be used in the destination cluster. Defined values are:
  • Minimum length: 0
  • Maximum length: 2
storageClasses
array[storageClasses]
False
The storage class to be used on the destination cluster when creating new Persistent Volume Claims (PVCs). Each JSON object contains the fields "clusterID" and "storageClassName", where the "clusterID" value is the JSON string ID of the source or destination cluster, and the "storageClassName" is the storage class to use when creating PVCs on that cluster. If not provided or if the value is missing for a cluster, the default storage class will be used for that cluster. Defined values are:
  • Minimum length: 0
  • Maximum length: 2
stateDesired
string
True
The desired state for the relationship. At creation, the only valid value is "established". Defined values are:
  • "established" - The relationship is created.
  • "failedOver" - Failover of the application to the destination cluster has completed.
  • "deleted" - The relationship was successfully cleaned up and deleted.
metadata
type_astra_metadata_update
False
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
Example request
  "type": "application/astra-appMirror",
  "version": "1.0",
  "sourceAppID": "efd639b6-fc92-4112-8841-0c0ab7890ae0",
  "destinationClusterID": "c5d023a9-4061-4a8a-bfbf-3be11ff06226",
  "stateDesired": "established"
Status: 201, Returns the newly created appMirror resource in the JSON response body.
type
string
True
version
string
True
  • "1.0"
id
string
True
sourceAppID
string
True
sourceClusterID
string
True
Identifier of the managed cluster hosting the source application. This field is read-only and is determined based on the host cluster of the source application. If provided in an update, it must match the cluster ID of the source application, so it can only change when swapping the sourceAppID with destinationAppID. Defined values are:
destinationAppID
string
False
Identifier of the destination application. Cannot be provided on create because a new app ID will be generated as part of relationship initialization. Can only be updated when swapping sourceAppID with the destinationAppID. Defined values are:
string
True
namespaceMapping
False
  • Minimum length: 0
  • Maximum length: 2
storageClasses
False
  • Minimum length: 0
  • Maximum length: 2
state
string
True
The state of the relationship. Defined values are:
  • "establishing" - The relationship is being created.
  • "failingOver" - Failover of the application to the destination cluster is in progress.
  • "deleting" - Resources created by the relationship are being cleaned up.
  • "deleted" - The relationship was cleaned up and deleted.
stateTransitions
array[type_astra_stateTransition]
False
Permitted state transitions. The following state transitions are possible for this resource:
  • "establishing": "established", "deleting"
  • "established": "failingOver", "deleting"
  • "failingOver": "failedOver", "deleting"
  • "failedOver": "establishing", "deleting"
  • "deleting": "deleted"
  • "deleted":
stateDesired
string
True
stateAllowed
array[string]
False
States that can be requested in a given state. The following states can be requested in each defined state:
  • "establishing": "established", "deleted"
  • "established": "failedOver", "deleted"
  • "failingOver": "failedOver", "deleted"
  • "failedOver": "established", "deleted"
  • "deleted": "deleted"
stateDetails
array[type_astra_stateDetail]
True
Additional details about the current state, including why the current state was reached. If no details are available, this array will be empty. Defined values are:
  • Minimum Items: 0
transferState
string
False
State of the current or most recent snapshot transfer. Defined values are:
  • "transferring" - A new snapshot was created and is now being replicated to the destination cluster. This state also covers the transfers that have failed on previous attempts and are being continually retried.
  • "idle" - There is currently no transfer in progress.
transferStateTransitions
False
Permitted state transitions from a given defined state. The following state transitions are possible for this resource:
  • "transferring": "idle"
  • "idle": "transferring"
transferStateDetails
False
Additional details about the current state including why the current state was reached. If no details are available, this array will be empty. Defined values are:
  • Minimum Items: 0
healthState
string
True
Health state of the resource. Defined values are:
  • "indeterminate" - The health of the resource cannot be determined (for example, due to lack of connectivity)
  • "normal" - The resource has no known issues and can provide services in accordance with the interface specification
  • "warning" - The resource has known issues that do not prevent it providing services in accordance with the interface specification
  • "critical" - The resource has known issues that prevent it from providing services in accordance with the interface specification
healthStateTransitions
True
  • "indeterminate": "normal", "warning", "critical"
  • "normal": "indeterminate", "warning", "critical"
  • "warning": "indeterminate", "normal", "critical"
  • "critical": "indeterminate", "normal", "warning"
healthStateDetails
True
  • Minimum Items: 0
metadata
True
  "version": "1.0",
  "id": "c5fbadd4-5d9e-5942-bb7f-f5386b6b6253",
  "sourceClusterID": "5789e026-c2e2-41e9-ab00-9766bcfa8951",
  "destinationAppID": "cd7b6d91-fc19-4983-a754-9a7bb4d80a7b",
  "state": "establishing",
  "stateTransitions": [
      "from": "establishing",
      "to": [
        "established",
        "deleting"
      "from": "established",
      "to": [
        "failingOver",
        "deleting"
      "from": "failingOver",
      "to": [
        "failedOver",
        "deleting"
      "from": "failedOver",
      "to": [
        "establishing",
        "deleting"
      "from": "deleting",
      "to": [
        "deleted"
  "stateDesired": "established",
  "stateAllowed": [
    "deleted"
  "stateDetails": [
      "type": "https://astra.netapp.io/stateDetails/3",
      "title": "AppMirror is being established",
      "detail": "The AppMirror relationship is in the process of being established."
  "healthState": "warning",
  "healthStateTransitions": [
      "from": "indeterminate",
      "to": [
        "normal",
        "warning",
        "critical"
      "from": "normal",
      "to": [
        "indeterminate",
        "warning",
        "critical"
      "from": "warning",
      "to": [
        "indeterminate",
        "normal",
        "critical"
      "from": "critical",
      "to": [
        "indeterminate",
        "normal",
        "warning"
  "healthStateDetails": [
      "type": "https://astra.netapp.io/stateDetails/4",
      "title": "AppMirror not yet established",
      "detail": "The relationship is in the process of being established, so it's not protecting the app data yet."
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidFields
array[invalidFields]
False
List of invalid request body fields
  "status": "400"
Status: 409, Conflict
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "409"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "status": "404"
namespaceMapping
clusterID
string
False
Identifier of the cluster for which the namespaces are specified. Defined values are:
namespaces
array[string]
False
List of namespaces to use on the cluster. Correlated with the other cluster namespace list by index. Defined values are:
  • Minimum length: 1
  • Maximum length: 63
  • Conforms to the DNS 1123 Label Schema
storageClasses
clusterID
string
False
Identifier of the cluster for which the storage class is specified. Defined values are:
storageClassName
string
False
Name of the storage class to use when creating PVCs on the cluster specified in "clusterID". Defined values are:
  • Minimum length: 1
  • Maximum length: 255
type_astra_label
name
string
True
value
string
True
labels
array[type_astra_label]
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
from
string
True
to
array[string]
True
type
string
True
title
string
True
detail
string
True
invalidParams
name
string
True
reason
string
True
invalidFields
name
string
True
Name of the invalid request body field
reason
string
True
Reason why the request body field is invalid
