Create a new bucket
Creates a new bucket in the Astra API, specifying the desired values for the Bucket API resource to be established.
HTTP method and endpoint
POST /accounts/{account_id}/topology/v1/buckets
Usage notes
Indicates the desired values for the Bucket API resource to be created.
account_id |
string |
path |
True |
Request Body
| Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
name |
string |
False |
JSON string containing a user-assigned name for the bucket. Defined values are:
credentialID |
string |
True |
JSON string containing the identifier of the credentials used to access the bucket. Defined values are:
provider |
string |
True |
JSON string indicating the bucket protocol that can be used to access the bucket. Defined values are:
bucketParameters |
True |
JSON object that provides bucket provider-specific information required to access the bucket. The specific values in this bucket vary per provider. |
metadata |
False |
Example request
"type": "application/astra-bucket",
"version": "1.2",
"name": "Test Bucket",
"credentialID": "d5b3854c-38de-42c6-9269-b5c052aba76f",
"provider": "gcp",
"bucketParameters": {
"gcp": {
"bucketName": "bucketName"
Status: 201, Returns the newly created bucket resource in the JSON response body.
type |
string |
True |
version |
string |
True |
id |
string |
True |
name |
string |
True |
credentialID |
string |
True |
state |
string |
True |
JSON string containing a value indicating the operational state of the bucket. Defined values are:
stateDetails |
array[type_astra_stateDetail] |
True |
JSON array of JSON objects that lists additional details about why "state" transitioned to "removed" or "failed". If no details are available, this array will be empty.
provider |
string |
True |
bucketParameters |
True |
metadata |
True |
"version": "1.2",
"id": "9b296ce0-c545-5022-acfa-1980c5aaea97",
"credentialID": "8f039324-7795-40bf-a5ca-4442580f7ab0",
"state": "available",
"stateDetails": [],
"provider": "gcp",
"gcp": {
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
array[invalidFields] |
False |
List of invalid request body fields |
"status": "400"
Status: 409, Conflict
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
False |
"status": "409"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
s3
JSON object that provides Simple Storage Service (S3) protocol parameters. (Use this object for all S3 type providers).
serverURL |
string |
True |
JSON string containing a URL to the base path for the bucket. Defined values are:
bucketName |
string |
True |
JSON string containing the name of the S3 bucket. Defined values are:
gcp
JSON object that provides Google Cloud protocol parameters.
bucketName |
string |
True |
JSON string containing the name of the backing Google Cloud bucket name. Defined values are:
azure
JSON object that provides Azure protocol parameters.
storageAccount |
string |
True |
JSON string containing the Azure storage account name. Defined values are:
bucketName |
string |
True |
JSON string containing the name of the backing Azure blob name. Defined values are:
bucketParameters
s3 |
False |
JSON object that provides Simple Storage Service (S3) protocol parameters. (Use this object for all S3 type providers). |
gcp |
False |
JSON object that provides Google Cloud protocol parameters. |
azure |
False |
JSON object that provides Azure protocol parameters. |
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
type |
string |
True |
title |
string |
True |
detail |
string |
True |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
invalidFields
name |
string |
True |
Name of the invalid request body field |
reason |
string |
True |
Reason why the request body field is invalid |
