Modify an account
Modifies an account by replacing the stored resource with the provided JSON request body, ensuring key values that are not user-modifiable remain intact.
HTTP method and endpoint
PUT /accounts/{account_id}
Usage notes
Replaces the entire stored resource with the supplied JSON request body while preserving the key values that are not user-modifiable.
Side Effects
Changing "isEnabled" from "false" to "true" sets "enabledTimestamp" to the current time.
account_id |
string |
path |
True |
ID of the account collection to list
Request Body
Side Effects
| Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
id |
string |
False |
name |
string |
False |
JSON string containing a name for the account. Defined values are:
state |
string |
False |
JSON string containing a value indicating the operational state of the account. Defined values are:
isEnabled |
string |
False |
JSON string indicating the account is enabled. Defined values are:
enabledTimestamp |
string |
False |
JSON string containing the timestamp indicating when the account was last enabled. If the account has never been enabled, this field is absent. Defined values are:
accountContact |
False |
JSON object containing user contact information to create an owner user at the time of account activation. |
metadata |
False |
Example request
"type": "application/astra-account",
"version": "1.0",
"name": "frightened-pine"
Status: 204, Indicates if the account resource was updated.
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
array[invalidFields] |
False |
List of invalid request body fields |
"status": "400"
Status: 409, Conflict
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
False |
"status": "409"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"type": "https://astra.netapp.io/problems/1",
"title": "Resource not found",
"detail": "The resource specified in the request URI wasn't found.",
"status": "404"
postalAddress
JSON object containing a collection of JSON strings specifying an address. If this key does not exist, it indicates that an address has not been provided. If this key exists, all six of the contained JSON strings will be present. If you provide nothing, the string will be empty.
addressCountry |
string |
False |
JSON string containing the country name or country code associated with the postal address, as specified in ISO 3166 Alpha-2. Defined values are:
addressLocality |
string |
False |
JSON string containing the locality (for example, city) associated with the postal address. Defined values are:
addressRegion |
string |
False |
JSON string containing the region (for example, state) associated with the postal address. Defined values are:
postalCode |
string |
False |
JSON string containing the postal code associated with the postal address. Defined values are:
streetAddress1 |
string |
False |
JSON string containing the street address associated with the postal address. Defined values are:
streetAddress2 |
string |
False |
JSON string containing optional ancillary street address information, post office box, and more. Defined values are:
accountContact
firstName |
string |
False |
JSON string containing a user specified long-form first name. Defined values are:
lastName |
string |
False |
JSON string containing a user specified long-form last name. Defined values are:
companyName |
string |
False |
JSON string containing the company name associated with the user. If this key does not exist, it indicates that a company name has not been provided. Defined values are:
string |
False |
JSON strings containing a user specified email address. Defined values are:
phone |
string |
False |
JSON string containing the phone number of the user. If this key does not exist, it indicates that a phone number has not been provided. Defined values are:
postalAddress |
False |
JSON object containing a collection of JSON strings specifying an address. If this key does not exist, it indicates that an address has not been provided. If this key exists, all six of the contained JSON strings will be present. If you provide nothing, the string will be empty. |
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
invalidFields
name |
string |
True |
Name of the invalid request body field |
reason |
string |
True |
Reason why the request body field is invalid |
